I am working on a project where I use the gps neo6vm2 module. I have a strange problem, namely the led on the module does not blink and does not connect to the satellites until I disconnect and reconnect the antenna.
I tried voltages 3.3 and 5 and also connecting another antenna (wifi antenna). After connecting another antenna, the module starts as it should but does not give correct coordinates.
Is the antenna faulty? Thank you in advance for any help.
if i connect and disconnect ceramic antenna after a few seconds it will give me my exact coordinates. But if I power the module and just wait without touching antenna it will not communicate.
By bad coordinates I meant "0.00000" in LAT and LNG
That is no co-ordinates, and what a GPS library will often report when there are no co-ordinates at all coming from the GPS when it does not have a fix.
Sounds like the GPS is not starting up the antenna properly somehow. Faulty GPS or antenna maybe.
