GPS NMEA output to readable format
Hi, I’m trying to convert NMEA output from an Argent GT-320FW(AS) GPS into something that is easier to read.
The NMEA output reads:
$GPGSA,A,1,*1E
$GPGSV,2,1,08,14,70,126,16,55,257,31,40,049,30,39,030,*73
$GPGSV,2,2,08,20,30,260,29,28,058,32,25,289,06,23,188,7B
$GPRMC,070913.00,V,2328.2385,N,12057.5213,E,210609,N
45
$GPGGA,070914.00,2328.2385,N,12057.5213,E,0,00,0.0,M,M,*55
and my code (borrowed liberally from various sources) is
#include <TinyGPS.h>
#include <SoftwareSerial.h>
TinyGPS convert;
#define RXPIN 2
#define TXPIN 6
SoftwareSerial GPS = SoftwareSerial(2,6);
  GPS.begin(4800);
  Serial.println("");
  Serial.println("GPS Arduino");
  Serial.println("       ...waiting for lock...           ");
  Serial.println("");
    while(GPS.available())
      int c = GPS.read();
      //Serial.println(c);
      Serial.print(convert.encode(c));
     float latitude, longitude;
   convert.f_get_position(&latitude, &longitude);
   Serial.print("Lat/Long: ");
   Serial.print(latitude,5);
   Serial.print(", ");
   Serial.println(longitude,5);
   int year;
   byte month, day, hour, minute, second, hundredths;
   convert.crack_datetime(&year,&month,&day,&hour,&minute,&second,&hundredths);
   Serial.print("Date: "); Serial.print(month, DEC); Serial.print("/");
  Serial.print(day, DEC); Serial.print("/"); Serial.print(year);
  Serial.print("  Time: "); Serial.print(hour, DEC); Serial.print(":");
  Serial.print(minute, DEC); Serial.print(":"); Serial.print(second, DEC);
  Serial.print("."); Serial.println(hundredths, DEC);
   Serial.print("Satellites: ");
  Serial.println(convert.satellites());
but it outputs
0Lat/Long: 1000.00000, 1000.00000
Date: 0/0/2000 Time: 198:96:72.95
Satellites: 255
Satellites: 255
Is there something wrong with my code, or is the GPS not working?
Thank you for the help!
You read a character from the GPS. You supply that character to the GPS library, and it tells you whether that completes a sentence, or not. Regardless of what the library says, you assume that it has a complete sentence, and you extract all the data from the usually incomplete sentence. How is that working? Never mind, I already know.
Well, yeah.
Why are you printing this value? Why are you NOT using the value in a if statement, to determine whether or not to execute the rest of the code? Extracting data from incomplete sentences is pointless.
Here is a working example - stuffing gps data into variables - http://arduinotronics.blogspot.com/2014/02/arduino-ublox-neo-6m-gps.html
