So I have this sketch that works for a GPS, I get the coordinates perfectly as I wish:
#include <Adafruit_GPS.h>
#include <SoftwareSerial.h>
SoftwareSerial mySerial(8, 7); // (TX, RX)
Adafruit_GPS GPS(&mySerial);
delay(5000);
Serial.println("Adafruit GPS library basic test!");
GPS.begin(9600);
GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCGGA);
GPS.sendCommand(PMTK_SET_NMEA_UPDATE_1HZ);
GPS.sendCommand(PGCMD_ANTENNA);
mySerial.println(PMTK_Q_RELEASE);
uint32_t timer = millis();
char c = GPS.read();
if ((c))
if (GPS.newNMEAreceived()) {
if (!GPS.parse(GPS.lastNMEA()))
return;
if (millis() - timer > 2000) {
timer = millis();
if (GPS.fix) {
Serial.print(GPS.latitudeDegrees, 4);
Serial.print(", ");
Serial.println(GPS.longitudeDegrees, 4);
But as soon as I put it in my total sketch it doesn't work:
#include <Servo.h>
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_Sensor.h>
#include "Adafruit_BME680.h"
bool maxheight = false;
bool deploy = false;
float servoAltitude = 0;
Servo servo;
#define BME_SCK 15
#define BME_MISO 14
#define BME_MOSI 16
#define BME_CS 3
#define SEALEVELPRESSURE_HPA (1026.32) // Meet de druk op de grond!
Adafruit_BME680 bme(BME_CS, BME_MOSI, BME_MISO, BME_SCK);
mySerial.begin(9600);
// BME680
if (!bme.begin()) {
Serial.println("Could not find a valid BME680 sensor, check wiring!");
while (1);
bme.setTemperatureOversampling(BME680_OS_8X);
bme.setHumidityOversampling(BME680_OS_2X);
bme.setPressureOversampling(BME680_OS_4X);
bme.setIIRFilterSize(BME680_FILTER_SIZE_3);
bme.setGasHeater(320, 150);
delay(5000);
// GPS
GPS.begin(9600);
// Servo Motor
delay(200);
servo.attach(6);
delay(200);
servo.write(90);
delay(200);
servo.detach();
delay(200);
// Parsing
if ((c))
return;
timer = millis();
// GPS
if (GPS.fix) {
Serial.print("\n");
Serial.print("Location:");
Serial.print(", ");
mySerial.print("\n");
mySerial.print("Location:");
mySerial.print(GPS.latitudeDegrees, 4);
mySerial.print(", ");
mySerial.println(GPS.longitudeDegrees, 4);
// BME680
Serial.print("\n");
Serial.print("Temperature = ");
Serial.print(bme.temperature);
Serial.println(" *C");
mySerial.print("Temperature = ");
mySerial.print(bme.temperature);
mySerial.println(" *C");
Serial.print("Pressure = ");
Serial.print(bme.pressure / 100.0);
Serial.println(" hPa");
mySerial.print("Pressure = ");
mySerial.print(bme.pressure / 100.0);
mySerial.println(" hPa");
Serial.print("Humidity = ");
Serial.print(bme.humidity);
Serial.println(" %");
mySerial.print("Humidity = ");
mySerial.print(bme.humidity);
mySerial.println(" %");
Serial.print("Gas = ");
Serial.print(bme.gas_resistance / 1000.0);
Serial.println(" KOhms");
mySerial.print("Gas = ");
mySerial.print(bme.gas_resistance / 1000.0);
mySerial.println(" KOhms");
Serial.print("Approx. Altitude = ");
Serial.print(bme.readAltitude(SEALEVELPRESSURE_HPA));
Serial.println(" m");
mySerial.print("Approx. Altitude = ");
mySerial.print(bme.readAltitude(SEALEVELPRESSURE_HPA));
mySerial.println(" m");
servoAltitude = bme.readAltitude(SEALEVELPRESSURE_HPA);
// Servo Motor
if (servoAltitude >= 100) { Serial.println("Above 100 m"); maxheight = true; Serial.println(maxheight);}
else { delay(1000); }
if (maxheight == true and servoAltitude <= 50)
Serial.println("Deploying...");
delay(100);
servo.attach(6);
delay(100);
servo.write(0);
delay(600);
servo.write(90);
delay(100);
servo.detach();
delay(100);
maxheight = !maxheight;
{ delay(1000); }
Does anyone know the problem?
