in trying to make the grove gps work with seeeduino xiao im using the code i found on here https://wiki.seeedstudio.com/Grove-GPS/ i just want to make it print the longitude and latitude in a simple format. here the code that it came with. i use chat gpt to make it work with the seeduino i just want it so show the cord in a simple way. any help is welcome.
sorry if my bad spelling
SoftwareSerial SoftSerial(2, 3);
unsigned char buffer[64]; // buffer array for data receive over serial port
int count=0; // counter for buffer array
SoftSerial.begin(9600); // the SoftSerial baud rate
Serial.begin(9600); // the Serial port of Arduino baud rate.
if (SoftSerial.available()) // if date is coming from software serial port ==> data is coming from SoftSerial shield
while(SoftSerial.available()) // reading data into char array
buffer[count++]=SoftSerial.read(); // writing data into array
if(count == 64)break;
Serial.write(buffer,count); // if no data transmission ends, write buffer to hardware serial port
clearBufferArray(); // call clearBufferArray function to clear the stored data from the array
count = 0; // set counter of while loop to zero
if (Serial.available()) // if data is available on hardware serial port ==> data is coming from PC or notebook
SoftSerial.write(Serial.read()); // write it to the SoftSerial shield
void clearBufferArray() // function to clear buffer array
for (int i=0; i<count;i++)
buffer[i]=NULL;
} // clear all index of array with command NULL
