gps only can get a group of longitude and latitude
Our GPS only can get a group of longitude and latitude. We have been mobile the GPS more about 5 meters.
But the longitude and latitude are the same as the initial position.
This program is from this website.
#include <NewSoftSerial.h> // Add to library folder
#include <TinyGPS.h> // Add to library folder
TinyGPS gps;
NewSoftSerial nss(6, 255); // Yellow wire to pin 6
nss.begin(4800);
Serial.println("Reading GPS");
bool newdata = false;
unsigned long start = millis();
while (millis() - start < 5000) { // Update every 5 seconds
if (feedgps())
newdata = true;
if (newdata) {
gpsdump(gps);
// Get and process GPS data
void gpsdump(TinyGPS &gps) {
float flat, flon;
unsigned long age;
gps.f_get_position(&flat, &flon, &age);
Serial.print(flat, 4); Serial.print(", ");
Serial.println(flon, 4);
// Feed data as it becomes available
bool feedgps() {
while (nss.available()) {
if (gps.encode(nss.read()))
return true;
return false;
Since the accuracy of a GPS is typically +/- 10 meters, moving only 5 meters is not likely to show variations in position. Really move somewhere else, and see what happens.
Five to ten meter accuracy is about right for commercially available GPS kit. If you need higher accuracy, you need to look at differential GPS.
