GPS only works when I click Reset on Arduino
I cannot work this out!
My Ublox 7n GPS module will only print data in the serial monitor once when I either click reset on my Arduino Uno or reopen and close my Serial monitor.
So whenever I have the serial monitor open and click reset on my Arduino it quickly spits out all the data on it and then stops, same when I open the serial monitor after being closed.
Here is my code:
#include "TinyGPS++.h"
void displayInfo();
const unsigned long PUBLISH_PERIOD = 1000;
double latitude = 0, longitude = 0;
TinyGPSPlus gps;
unsigned long lastPublish = 0;
        while (Serial.available() > 0) {
          if (gps.encode(Serial.read())) {
            displayInfo();
//      latitude = gps.location.lat();
//      longitude = gps.location.lng();
//      Serial.println(gps.location.lat());
//      Serial.println(gps.location.lng());
//      Serial.println(latitude, 8);
//      Serial.println(longitude, 8);
      Serial.println("new");
void displayInfo()
  if (millis() - lastPublish >= PUBLISH_PERIOD) {
    lastPublish = millis();
      char buf[128];
      if (gps.location.isValid()) {
        snprintf(buf, sizeof(buf), "%lf,%lf", gps.location.lat(), gps.location.lng());
      //  Serial.println(buf);
      else {
        Serial.println("no location");
I’ve attached an image of my serial monitor, the gps data came through when I closed and reopened it.
Delete the line with the delay() call.
You have the GPS on the same serial port as the serial monitor ?
I've worked out the problem without a solution. For some reason when I connect the RX and TX pins on the module respectively to the RX and TX pins on the arduino, I get my location except that bug happens.
HOWEVER, if I flip the pins so RX->TX & TX-> RX I no longer have the bug ALTHOUGH it now prints 'no location'.
For some reason the location data is being lost when the pins are connected how they should be.
angusryan_:
See #2.
You do need to put the GPS on a different serial port to the serial monitor.
How do I do that ? (sorry still learning the way)
Also observed your profile and would love to have a quick small chat if you don't mind, you seem to have completed similar projects to what I am trying right now! (LoRa + GPS)
Take a look at the examples in the TinyGPS library folder.
On a UNO you will need to use software serial to read the GPS, just like the examples do.
the pps is flickering, I think its causing the problems. I ran the device example.
Follow the troubleshooting steps here;
GPS Tutorial
angusryan_ created a new thread for the PPS LED flickering thing:
