GPS Parsing and Accelerator
I am trying to combine two sketches. The GPS Parsing sketch and the Sensor test from the Adafruit ADXL 343. When I run the serial monitor only the acceleration data posts, unless I delete the acceleration loop then gps will post. I want them to post incoherently and eventually post to an SD card.
Here is my code
uint32_t timer = millis();
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_ADXL343.h>
/* Assign a unique ID to this sensor at the same time /
Uncomment following line for default Wire bus */
Adafruit_ADXL343 accel = Adafruit_ADXL343(12345);
/* NeoTrellis M4, etc. /
Uncomment following line for Wire1 bus */
//Adafruit_ADXL343 accel = Adafruit_ADXL343(12345, &Wire1);
void displayDataRate(void)
Serial.print ("Data Rate: ");
switch (accel.getDataRate())
case ADXL343_DATARATE_3200_HZ:
Serial.print ("3200 ");
case ADXL343_DATARATE_1600_HZ:
Serial.print ("1600 ");
case ADXL343_DATARATE_800_HZ:
Serial.print ("800 ");
case ADXL343_DATARATE_400_HZ:
Serial.print ("400 ");
case ADXL343_DATARATE_200_HZ:
Serial.print ("200 ");
case ADXL343_DATARATE_100_HZ:
Serial.print ("100 ");
case ADXL343_DATARATE_50_HZ:
Serial.print ("50 ");
case ADXL343_DATARATE_25_HZ:
Serial.print ("25 ");
case ADXL343_DATARATE_12_5_HZ:
Serial.print ("12.5 ");
case ADXL343_DATARATE_6_25HZ:
Serial.print ("6.25 ");
case ADXL343_DATARATE_3_13_HZ:
Serial.print ("3.13 ");
case ADXL343_DATARATE_1_56_HZ:
Serial.print ("1.56 ");
case ADXL343_DATARATE_0_78_HZ:
Serial.print ("0.78 ");
case ADXL343_DATARATE_0_39_HZ:
Serial.print ("0.39 ");
case ADXL343_DATARATE_0_20_HZ:
Serial.print ("0.20 ");
case ADXL343_DATARATE_0_10_HZ:
Serial.print ("0.10 ");
default:
Serial.print ("???? ");
Serial.println(" Hz");
void displayRange(void)
Serial.print ("Range: +/- ");
switch (accel.getRange())
case ADXL343_RANGE_16_G:
Serial.print ("16 ");
case ADXL343_RANGE_8_G:
Serial.print ("8 ");
case ADXL343_RANGE_4_G:
Serial.print ("4 ");
case ADXL343_RANGE_2_G:
Serial.print ("2 ");
default:
Serial.print ("?? ");
Serial.println(" g");
#include <Adafruit_GPS.h>
// what's the name of the hardware serial port?
#define GPSSerial Serial1
// Connect to the GPS on the hardware port
Adafruit_GPS GPS(&GPSSerial);
// Set GPSECHO to 'false' to turn off echoing the GPS data to the Serial console
// Set to 'true' if you want to debug and listen to the raw GPS sentences
#define GPSECHO false
while (!Serial);
Serial.println("Accelerometer Test"); Serial.println("");
/* Initialise the sensor /
if (!accel.begin())
There was a problem detecting the ADXL343 ... check your connections */
Serial.println("Ooops, no ADXL343 detected ... Check your wiring!");
while (1);
/* Set the range to whatever is appropriate for your project */
accel.setRange(ADXL343_RANGE_16_G);
// accel.setRange(ADXL343_RANGE_8_G);
// accel.setRange(ADXL343_RANGE_4_G);
// accel.setRange(ADXL343_RANGE_2_G);
/* Display some basic information on this sensor */
accel.printSensorDetails();
displayDataRate();
displayRange();
Serial.println("");
//while (!Serial); // uncomment to have the sketch wait until Serial is ready
// connect at 115200 so we can read the GPS fast enough and echo without dropping chars
// also spit it out
Serial.println("Adafruit GPS library basic test!");
// 9600 NMEA is the default baud rate for Adafruit MTK GPS's- some use 4800
GPS.begin(9600);
// uncomment this line to turn on RMC (recommended minimum) and GGA (fix data) including altitude
GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCGGA);
// uncomment this line to turn on only the "minimum recommended" data
//GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCONLY);
// For parsing data, we don't suggest using anything but either RMC only or RMC+GGA since
// the parser doesn't care about other sentences at this time
// Set the update rate
GPS.sendCommand(PMTK_SET_NMEA_UPDATE_1HZ); // 1 Hz update rate
// For the parsing code to work nicely and have time to sort thru the data, and
// print it out we don't suggest using anything higher than 1 Hz
// Request updates on antenna status, comment out to keep quiet
GPS.sendCommand(PGCMD_ANTENNA);
// Ask for firmware version
GPSSerial.println(PMTK_Q_RELEASE);
/* Get a new sensor event */
sensors_event_t event;
accel.getEvent(&event);
/* Display the results (acceleration is measured in m/s^2) */
Serial.print("X: "); Serial.print(event.acceleration.x); Serial.print(" ");
Serial.print("Y: "); Serial.print(event.acceleration.y); Serial.print(" ");
Serial.print("Z: "); Serial.print(event.acceleration.z); Serial.print(" "); Serial.println("m/s^2 ");
// read data from the GPS in the 'main loop'
char c = GPS.read();
// if you want to debug, this is a good time to do it!
if (GPSECHO)
if (c) Serial.print(c);
// if a sentence is received, we can check the checksum, parse it...
if (GPS.newNMEAreceived()) {
// a tricky thing here is if we print the NMEA sentence, or data
// we end up not listening and catching other sentences!
// so be very wary if using OUTPUT_ALLDATA and trying to print out data
Serial.println(GPS.lastNMEA()); // this also sets the newNMEAreceived() flag to false
if (!GPS.parse(GPS.lastNMEA())) // this also sets the newNMEAreceived() flag to false
return; // we can fail to parse a sentence in which case we should just wait for another
// approximately every 2 seconds or so, print out the current stats
if (millis() - timer > 2000) {
timer = millis(); // reset the timer
Serial.print("\nTime: ");
if (GPS.hour < 10) {
Serial.print('0');
Serial.print(GPS.hour, DEC); Serial.print(':');
if (GPS.minute < 10) {
Serial.print('0');
Serial.print(GPS.minute, DEC); Serial.print(':');
if (GPS.seconds < 10) {
Serial.print('0');
Serial.print(GPS.seconds, DEC); Serial.print('.');
if (GPS.milliseconds < 10) {
Serial.print("00");
} else if (GPS.milliseconds > 9 && GPS.milliseconds < 100) {
Serial.print("0");
Serial.println(GPS.milliseconds);
Serial.print("Date: ");
Serial.print(GPS.day, DEC); Serial.print('/');
Serial.print(GPS.month, DEC); Serial.print("/20");
Serial.println(GPS.year, DEC);
Serial.print("Fix: "); Serial.print((int)GPS.fix);
Serial.print(" quality: "); Serial.println((int)GPS.fixquality);
if (GPS.fix) {
Serial.print("Location: ");
Serial.print(GPS.latitude, 4); Serial.print(GPS.lat);
Serial.print(", ");
Serial.print(GPS.longitude, 4); Serial.println(GPS.lon);
Serial.print("Speed (knots): "); Serial.println(GPS.speed);
Serial.print("Angle: "); Serial.println(GPS.angle);
Serial.print("Altitude: "); Serial.println(GPS.altitude);
Serial.print("Satellites: "); Serial.println((int)GPS.satellites);
7quin:
Here is my code
Try taking the "delay(1000);" out of the first part. It will be very hard to keep up with the GPS input if you only look a one character per second.
There should probably be an "if (GPS.available())" before the "char c = GPS.read();".
