GPS Parsing program error
hey… i just uploaded the adafruit GPS library’s “parsing” program in my arduino but it is not showing proper output… i checked everything i.e all the connection and baudrate but still its the same… i hav attached the output i got below… can u please help me??
It’s likely that your unit just hasn’t acquired a lock on the satellites. Give it a clear view of the sky, and at least 15 minutes.
That is perfectly proper output, for no fix.
Where do you have your GPS antenna? If it’s just a receiver, the antenna is probably a square ceramic looking thing on it. Some cheaper units need an external antenna. I get a good fix indoors just fine at home, but I cannot get a fix inside at all at work. Try taking your unit outside, point it up, and then monitor the output.
