Gps problem on arduino
Hello. We have project about an GSM Shield. We are tying to send the location of our device using SMS via a GPS through the GSM shield. We don't have any technical problems altough we get an empty message every time we try to get the location from the GPS. We are not sure about which Digital Pin we should connect the GPS through.
kodu buraya gir veya yapıştır
#include <KapadokyaGSM.h>
KapadokyaGSM Kapadokya;
String smsMetni, smsNumarasi;
#define gonderilecekTelNumarasi "+90532111xxxx" //
#define LED_pin 13
#define GPS Serial
#include <TinyGPS.h>
TinyGPS gps;
double enl;
double boy;
String konum;
char konum2[255];
Kapadokya.basla();
delay(2000);
pinMode(LED_pin, OUTPUT);
GPS.begin(9600);
delay(2000);
Kapadokya.tumSmsSil();
delay(2000);
Kapadokya.smsGonder(gonderilecekTelNumarasi, "Sistem acildi.");
smsMetni = Kapadokya.smsOku(1);
if (smsMetni.indexOf("OK") != -1) {
if (smsMetni.length() > 7) {
smsNumarasi = Kapadokya.numaraliSmsOku(1);
smsMetni.toUpperCase();
  if (smsMetni.indexOf("LEDAC") != -1) {
    digitalWrite(LED_pin, HIGH);
    Kapadokya.smsGonder(gonderilecekTelNumarasi, "LED Acildi");
  else if (smsMetni.indexOf("LEDKAPAT") != -1) {
    digitalWrite(LED_pin, LOW);
    Kapadokya.smsGonder(gonderilecekTelNumarasi, "LED Kapatildi");
  else if (smsMetni.indexOf("NERDESIN") != -1 || smsMetni.indexOf("NEREDESIN") != -1 || smsMetni.indexOf("KONUM") != -1) {
    bool yeniVeri = false;
    for (unsigned long start = millis(); millis() - start < 1000;) {`Önceden biçimlendirilmiş yazı`
      while (GPS.available()) {
        char c = GPS.read();
        if (gps.encode(c))
          yeniVeri = true;
    if (yeniVeri) {
      float flat, flon;
      unsigned long age;
      gps.f_get_position(&flat, &flon, &age);
      enl = flat;
      boy = flon;
      konum = "www.google.com.tr/maps/place/" + String(enl, 6) + "," + String(boy, 6);
      konum.toCharArray(konum2, 100);
    char konum2[255];
    Kapadokya.smsGonder(gonderilecekTelNumarasi, konum2);
  else {
Forget all the SMS stuff for a moment.
Do the basic example sketches in you GPS library report a fix ?
The TinyGPSplus library is more up to date than the earlier TinyGPS one.
Don't use delay like You do. Those 1 second delays makes GPS messages get lost.
We did try that It still didn’t worked.
Take another look at reply #2 - there is no point messing with texting until you prove to yourself that the GPS is working.
