so after a bit of rewiring and poking around, I've gotten the Globalsat 406a (http://www.usglobalsat.com/store/download/46/em406a_ug.pdf)
to talk to the Mega 2650 through an Adafruit shield Adafruit GPS logger shield kit [v1.1] : ID 98 : $19.50 : Adafruit Industries, Unique & fun DIY electronics and kits.
It'll read properly parsed empty phrases from the module indoors, and if I take it outside, it gets a bit more data.
But the problem is, it can see 12 satellites, but can't get a fix. Tried it at work, tried it at home, same results.
I let it chug along for at least 5 minutes, no luck. Sees 12, no fix. Moving it, sometimes it even loses the $GPGSV phrase.
If it was a radio, I'd change the antenna, but this one's part of the module.
Using the Adafruit code modified to read through the hardware serial port 1, I get:
Read:
$GPGGA,064518.403,,,,,0,00,,,M,0.0,M,,0000*5F
Read:
$GPGSA,A,1,,,,,,,,,,,,,,,*1E
Read:
$GPGSV,3,1,12,21,52,183,23,29,52,062,30,30,51,303,26,31,44,226,*7B
Read:
$GPGSV,3,2,12,25,33,127,,16,18,304,,05,16,051,,06,13,264,*73
Read:
$GPGSV,3,3,12,18,02,153,,23,02,313,,13,01,342,,03,-1,265,*6C
Read:
$GPRMC,064518.403,V,,,,,,,090612,,,N*48
Time: 6:45:18
Date: 6/9/12
Lat: 0* 0' 0.0"
Long: 0* 0' 0.0"
but even a simple serial1 to serial0 repeater gives the same results.
I'm GPS- clueless. Is there something obvious I could be missing?
Thanks,
t
