GPS + RF module
Good evening,
I would ask help to solve a simple problem. I’m creating a simple code with an GPS shield and RF module but when I activate the string SetupRFDataTxnLink(transmit_pin, baudRate) and all the parts related to the RF module, the GPS doesn’t work. If I comment them the GPS works and in the Serial Monitor the coordinates appear.
The simple code is:
#include "TinyGPS++.h"
#include "SoftwareSerial.h"
#include <VirtualWire.h>
#include <string.h>
#include <stdio.h>
#include <DataCoder.h>
SoftwareSerial serial_connection(10, 11);
TinyGPSPlus gps;
int transmit_pin = 12;
int baudRate = 1000;
  SetupRFDataTxnLink(transmit_pin, baudRate);
  serial_connection.begin(9600);
  Serial.println("GPS Start");
  float outArray[RF_DATA_ARRAY_SIZE];
  while(serial_connection.available())
    gps.encode(serial_connection.read());
  if(gps.location.isUpdated())
  outArray[1] = (gps.location.lat(), 6);
  outArray[2] = (gps.location.lng(), 6);
  union RFData outDataSeq;
  EncodeRFData(outArray, outDataSeq);
  TransmitRFData(outDataSeq);
    Serial.println("Latitude:");
    Serial.println(gps.location.lat(), 6);
    Serial.println("Longitude:");
    Serial.println(gps.location.lng(), 6);
Thank you very much
Best Regards
Denis Sangaletti
One major problem is SoftwareSerial. It blocks interrupts every time a GPS character comes in. You should use AltSoftSerial if you can put the GPS on pins 8 & 9. If not, try my NeoSWSerial instead. Both are much more efficient than SoftwareSerial.
You may also be interested in a smaller, faster GPS library, NeoGPS. Here is a NeoGPS & NeoSWSerial version of your sketch:
#include <NMEAGPS.h>
#include <NeoSWSerial.h>
NeoSWSerial gps_port(10, 11);
NMEAGPS     gps;
  Serial.println( F("GPS Start") );  // F macro saves RAM
  gps_port.begin(9600);
  while (gps.available( gps_port ))
    gps_fix fix = gps.read();
    if (fix.valid.location)
      outArray[0] = fix.latitude();  // Arrays start at 0, not 1.  Did you really mean [1] here?
      outArray[1] = fix.longitude();
      Serial.println( F("Latitude:") );
      Serial.println( outArray[0], 6 );
      Serial.println( F("Longitude:") );
      Serial.println( outArray[1], 6 );
Notice that it checks to make sure you actually have a location value. If the satellite reception is bad, you may not have a location.
NeoGPS is available from the Arduino IDE 1.6.x Library Manager, or you can download the ZIP from the link above.
Cheers,
/dev
Thank you really really much. Now works correctly.
I'm sorry for the index numbers: when I formulated the question I deleted some useless parts and I forgot to change the numbers.
If I can, I would add another question.
with the gps shield I can obtain something like that Latitude: 45.465421 Longitude: 9.185924
but I receive just 45.50 and 9.20 when I would receive all the decimal part of the coordinates. Can you help me to correct the code in order to send all the numbers?
Thank you really much for your availability Best regard Denis Sangaletti
What do you think the , 6 crap there is doing? It is NOT.
The code you didn't post now does what you want, except it doesn't really, and you want to know why. Well, that's obvious. Something is wrong with the code you didn't post.
I’m sorry…
The trasmitter code is the same as suggested by /dev. The receiver code, instead is:
const int rx_pin = 11;
const int led_pin = 13;
const int baudRate = 1000;
  pinMode(led_pin,OUTPUT);
  digitalWrite(led_pin,LOW);
  SetupRFDataRxnLink(rx_pin, baudRate);
  uint8_t buf[VW_MAX_MESSAGE_LEN];
  uint8_t buflen = VW_MAX_MESSAGE_LEN;
  union RFData inDataSeq;//To store incoming data
  float inArray[RF_DATA_ARRAY_SIZE];//To store decoded information
  if(RFLinkDataAvailable(buf, &buflen))
        digitalWrite(led_pin, HIGH);
        for(int i =0; i< buflen; i++)
          inDataSeq.s[i] = buf[i];
        digitalWrite(led_pin, LOW);
        DecodeRFData(inArray, inDataSeq);
        Serial.print("Incoming:");
        for (int i=0; i < RF_DATA_ARRAY_SIZE; i++)
            Serial.print(inArray[i]);
            Serial.print(", ");
and I would like to receive more precise coordinates.
Thank you very much
Best regard
Denis
It is receiving the full precision sent by the transmitter, but it is only printing 2 decimals. The default print of a float only shows 2 digits after the decimal point. You can tell it to print more:
    Serial.print( inArray[nobbc][i][/nobbc][b][size=3], 6[/size][/b] );
However, a float only has 7 significant digits, so 45.465421 is only good to 5 decimal places (2 for the "45" leaves 5 for the ".46542"). The 9.185924 is correct with 7 digits (1 for "9" and 6 for ".185924").
Cheers, /dev
thank you really much for your help,
But in this case I obtain 9.200000 and not 9.185924. Maybe I forgot something when I define the message sent with the RF module.
Maybe, do you know what I forgot?
thank you really really much again. Best Regards Denis
Ok, that's officially weird. It's not easy to round like that.
Please post the transmitter and the receiver code again, just to be sure.
Also attach the files (or a zip) of the DataCoder library. Select the "Attachments and other options" in the lower-left corner.
Cheers, /dev
thank you…
the trasmitter code is
NMEAGPS     gps;
      outArray[0] = (fix.latitude());
      outArray[1] = (fix.longitude());
the receiver code, instead,is
  //RF_DATA_ARRAY_SIZE can be changed if need be inside DataCoder.h
        //Do something with the information that have been received
        Serial.print("Incoming Data:");
            Serial.print(inArray[i], 6 );
            Serial.print(", ");
          Serial.print("Bytes Used:");
          Serial.println(RF_DATA_ARRAY_SIZE * 2);
Best regards
Denis
DataCoder.zip (7.82 KB)
Dear /Dev,
I think to have found the problem. If you look the file DataCoder.h there are the following lines:
#define RF_DATA_ARRAY_SIZE 4 //The number of elements to be held in the array
#define RF_DATA_DECIMAL_PLACES 1//The number of decimal places that will be encoded
#define UNION_EXPANSION_FACTOR 2//The number of bytes occupied by each element of the encoded RFData packet. This data is //stored in dataBox[]. See below.
I imposed the following data:
define RF_DATA_ARRAY_SIZE 2
define RF_DATA_DECIMAL_PLACES 4
define UNION_EXPANSION_FACTOR 4
and now I obtain this:
Trasmitter: 45.726005, 9.655824
Receiver: Incoming Data: 45.724998, 9.650000, Bytes Used:4
I don't understand why I cannot receive for example
45.726000, 9.656 or more precise numbers
Can you help me to understand where I made mistakes?
thank you really really much Best regard Denis
After looking at the DataCoder library, I have to ask: Do you have to use the DataCoder library? It is limited to 5 significant digits, like you are seeing.
It would be much easier to use the basic sender/receiver examples in the VirtualWire library. Here is your transmitter sketch without the DataCoder library:
NMEAGPS     gps;
const int transmit_pin = 12;
const int LED          = 13;
  if (sizeof(gps_fix) > VW_MAX_PAYLOAD) {
    Serial.print( F("ERROR - fix message size too large: ") );
    Serial.print( sizeof(gps_fix) );
    Serial.print( F(" > MAX ") );
    Serial.println( VW_MAX_PAYLOAD );
    Serial.println( F("Edit Libraries/NeoGPS/GPSfix_cfg.h and comment out some of the #defines") );
    for (;;); // stop here!
  // Initialise the IO and ISR
  vw_set_tx_pin(transmit_pin);
//vw_set_rx_pin(rx_pin);
  vw_setup(baudRate);       // Bits per sec
  pinMode( LED, OUTPUT );
  digitalWrite( LED, LOW );
  // Check for GPS data
      Serial.println( fix.latitude(), 6 );
      Serial.println( fix.longitude(), 6 );
      // Only send another fix if the previous one was finished sending
      if (!vx_tx_active())
        // Send the entire fix
        vw_send( (uint8_t *)&fix, sizeof(fix) );
  // Show transmitter status
  digitalWrite( LED, vx_tx_active() );
It just sends all the bytes of a fix. The receiver will get everything you have configured in GPSfix_cfg.h, including the valid flags. Remove the LED statements if you don’t want to flash the on-board LED.
The receiver sketch should be something like this:
  Serial.println( F("GPS Receiver Start") );
//  vw_set_tx_pin(transmit_pin);
  // Check for received RF data
  if (vw_get_message(buf, &buflen)) // Non-blocking
    if (buflen == sizeof(gps_fix)) {
      // Map the received characters onto a fix structure
      gps_fix & fix = *((gps_fix *)buf);
        Serial.print( fix.latitude(), 6 );
This should receive the exact same fix structure that was filled out by NeoGPS on the transmitting Arduino. It has extra precision in latitudeL and longitudeL. See NMEAloc.ino for an example of printing out those long integers (instead of float) if you want the extra precision (7 decimals).
Cheers,
/dev
