GPS Shield Problem . . .
I am doing the project by using arduino UNO v3 and a gps shield withSD card slot. The gps chip is GlobalSat EB-5365RE . The programme is based on the sample code of online tutorial.After i upload the code. The serial monotior show strange symbol. But when i press "RESET Button the serial monitor show the NEMA sentence normally.
Also, i change the baud rate to 115200 and not data is received.
Is there any problem of my code and the configuration of my arduino.
My code is below.
#include <SoftwareSerial.h>
#include <TinyGPS.h>
/* This sample code demonstrates the normal use of a TinyGPS object.
It requires the use of SoftwareSerial, and assumes that you have a
4800-baud serial GPS device hooked up on pins 1(rx) and 0(tx).
TinyGPS gps;
SoftwareSerial nss(0, 1);
static void gpsdump(TinyGPS &gps);
static bool feedgps();
static void print_float(float val, float invalid, int len, int prec);
static void print_int(unsigned long val, unsigned long invalid, int len);
static void print_date(TinyGPS &gps);
static void print_str(const char *str, int len);
Serial.begin(115200);//Show in serial monitor
nss.begin(9600); //GPS baud rate
Serial.print("Testing TinyGPS library v. "); Serial.println(TinyGPS::library_version()); //TinyGPS::library_version() function from .h file
Serial.println("by Mikal Hart");
Serial.print("Sizeof(gpsobject) = "); Serial.println(sizeof(TinyGPS));
Serial.println("Sats HDOP Latitude Longitude Fix Date Time Date Alt Course Speed Card Distance Course Card Chars Sentences Checksum");
Serial.println(" (deg) (deg) Age Age (m) --- from GPS ---- ---- to London ---- RX RX Fail");
Serial.println("--------------------------------------------------------------------------------------------------------------------------------------");
bool newdata = false;
unsigned long start = millis();
while (millis() - start < 5000){
if (feedgps())
newdata = true; // Renew boolean newdata
gpsdump(gps);
float flat, flon;
unsigned long age, date, time, chars = 0;
unsigned short sentences = 0, failed = 0;
static const float LONDON_LAT = 51.508131, LONDON_LON = -0.128002;
//Print data based on diff. format int/flot/str
print_int(gps.satellites(), TinyGPS::GPS_INVALID_SATELLITES, 5);
print_int(gps.hdop(), TinyGPS::GPS_INVALID_HDOP, 5);
gps.f_get_position(&flat, &flon, &age);
print_float(flat, TinyGPS::GPS_INVALID_F_ANGLE, 9, 5);
print_float(flon, TinyGPS::GPS_INVALID_F_ANGLE, 10, 5);
print_int(age, TinyGPS::GPS_INVALID_AGE, 5);
print_date(gps);
print_float(gps.f_altitude(), TinyGPS::GPS_INVALID_F_ALTITUDE, 8, 2);
print_float(gps.f_course(), TinyGPS::GPS_INVALID_F_ANGLE, 7, 2);
print_float(gps.f_speed_kmph(), TinyGPS::GPS_INVALID_F_SPEED, 6, 2);
print_str(gps.f_course() == TinyGPS::GPS_INVALID_F_ANGLE ? "*** " : TinyGPS::cardinal(gps.f_course()), 6);
print_int(flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0UL : (unsigned long)TinyGPS::distance_between(flat, flon, LONDON_LAT, LONDON_LON) / 1000, 0xFFFFFFFF, 9);
print_float(flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : TinyGPS::course_to(flat, flon, 51.508131, -0.128002), TinyGPS::GPS_INVALID_F_ANGLE, 7, 2);
print_str(flat == TinyGPS::GPS_INVALID_F_ANGLE ? "*** " : TinyGPS::cardinal(TinyGPS::course_to(flat, flon, LONDON_LAT, LONDON_LON)), 6);
gps.stats(&chars, &sentences, &failed);
print_int(chars, 0xFFFFFFFF, 6);
print_int(sentences, 0xFFFFFFFF, 10);
print_int(failed, 0xFFFFFFFF, 9);
char sz[32];
if (val == invalid)
strcpy(sz, "*******");
sprintf(sz, "%ld", val);
sz[len] = 0;
for (int i=strlen(sz); i<len; ++i)
sz = ' ';
  • if (len > 0)*
  • sz[len-1] = ' ';*
  • Serial.print(sz);*
  • feedgps();*
  • char sz[32];*
  • if (val == invalid)*
    _ strcpy(sz, "*******");_
  • sz[len] = 0;*
  • if (len > 0)*
  • sz[len-1] = ' ';*
  • for (int i=7; i<len; ++i)*
    _ sz = ' ';_
    * Serial.print(sz);*
    * else*
    * Serial.print(val, prec);*
    * int vi = abs((int)val);*
    * int flen = prec + (val < 0.0 ? 2 : 1);*
    * flen += vi >= 1000 ? 4 : vi >= 100 ? 3 : vi >= 10 ? 2 : 1;*
    * for (int i=flen; i<len; ++i)*
    * Serial.print(" ");*
    * feedgps();*
    * int year;*
    * byte month, day, hour, minute, second, hundredths;*
    * unsigned long age;*
    * gps.crack_datetime(&year, &month, &day, &hour, &minute, &second, &hundredths, &age);
    if (age == TinyGPS::GPS_INVALID_AGE)
    _ Serial.print("****** ******* ");
    * else*
    * char sz[32];*
    * sprintf(sz, "%02d/%02d/%02d %02d:%02d:%02d ",*
    * month, day, year, hour, minute, second);*
    * print_int(age, TinyGPS::GPS_INVALID_AGE, 5);
    _
    feedgps();*
    static void print_str(const char str, int len)
    _
    {_
    _
    int slen = strlen(str);_
    _
    for (int i=0; i<len; ++i)_
    _ Serial.print(i<slen ? str : ' ');
    feedgps();
    static bool feedgps() //Check gps data
    while (nss.available())
    if (gps.encode(nss.read()))
    return true;
    return false;
    }_
    EB-5365RE_User_manual.pdf (334 KB)
    ArduinoGPSshield_Schematic.pdf (57.2 KB)
