Buona sera ho acquistato da poco questa shield: http://www.aeasport.it/home/107-arduino-scheda-gps.html
Ho trovato sul sito dfrobot questo sketch di esempio ma non funziona
#if defined(ARDUINO) && ARDUINO >= 100
#include "Arduino.h"
#define WireSend(args) Wire.write(args)
#define WireRead(args) Wire.read(args)
#define printByte(args) Serial.write(args)
#define printlnByte(args) Serial.write(args),Serial.println()
#else
#include "WProgram.h"
#define WireSend(args) Wire.send(args)
#define WireRead(args) Wire.receive(args)
#define printByte(args) Serial.print(args,BYTE)
#define printlnByte(args) Serial.println(args,BYTE)
#endif
#include <Wire.h>
#define BUFFER_LENGTH 10//Define the buffer length
int GPSAddress = 0x42;//GPS I2C Address
double Datatransfer(char *data_buf,char num)//Data type converter?convert char type to float
{ //*data_buf:char data array ;num:float length
double temp=0.0;
unsigned char i,j;
if(data_buf[0]=='-')
i=1;
while(data_buf[i]!='.')
temp=temp*10+(data_buf[i++]-0x30);
for(j=0;j<num;j++)
temp=temp*10+(data_buf[++i]-0x30);
for(j=0;j<num;j++)
temp=temp/10;
temp=0-temp;
else {
i=0;
for(j=0;j<num;j++)
for(j=0;j<num;j++)
temp=temp/10 ;
return temp;
void rec_init()//initial GPS
Wire.beginTransmission(GPSAddress);
WireSend(0xff);
Wire.endTransmission();
Wire.requestFrom(GPSAddress,10);
char ID()//?????ID
char i = 0;
char value[7]={
A me sembra strano visto che stiamo parlando dello stesso chip.,'G','P','G','G','A',',' };
char buff[7]={
'0','0','0','0','0','0','0' };
while(1)
rec_init();
while(Wire.available())
buff[i] = WireRead();
if(buff[i]==value[i])
i++;
if(i==7)
return 1;
i=0;
void UTC(){
char i = 0,flag=0;
char value[7]={
char buff[7]={
char time[9]={
'0','0','0','0','0','0','0','0','0' };
double t=0.0;
while(1)
rec_init();
if(!flag)
i++;
if(i==7)
i=0;
flag=1;
i=0;
time[i] = WireRead();
i++;
if(i==9)
t=Datatransfer(time,2);
t=t+80000.00;
Serial.println(t);
return;
void rec_data(char *buff,char num1,char num2)
{ //*buff???????????num1??????num2??????
char i=0,count=0;
if(ID())
while(1)
rec_init();
if(count!=num1)
if(buff[i]==',')
count++;
i++;
if(i==num2)
return;
void latitude(){
char lat[10]={
'0','0','0','0','0','0','0','0','0','0' };
rec_data(lat,1 ,10);
Serial.println(Datatransfer(lat,5),5);
void lat_dir(){
char dir[1]={'0'};
rec_data(dir,2,1);
printlnByte(dir[0]);
void longitude(){
char lon[11]={
'0','0','0','0','0','0','0','0','0','0','0' };
rec_data(lon,3,11);
Serial.println(Datatransfer(lon,5),5);
void lon_dir(){
char dir[1]={'0'};
rec_data(dir,4,1);
void altitude(){
char i=0,count=0;
char alt[8]={
if(ID())
while(1)
rec_init();
alt[i] = WireRead();
if(count!=8)
if(alt[i]==',')
count++;
if(alt[i]==',')
Serial.println(Datatransfer(alt,1),1);
return;
i++;
Wire.begin();
Serial.println("DFRobot DFRduino GPS Shield v1.0");
Serial.println("$GPGGA statement information: ");
while(1)
Serial.print("UTC:");
UTC();
Serial.print("Lat:");
latitude();
Serial.print("Dir:");
lat_dir();
Serial.print("Lon:");
longitude();
lon_dir();
Serial.print("Alt:");
altitude();
Serial.println(' ');
