GPS SIM908
Hi
I bought:
  • ARDUINO UNO REV3 CON ATMEGA328
  • 7100-FT971 (SIM908 MINIATURIZZATO)
  • Shield 8190-GSMGPRSSHIELDv2
  • 8160-ANTGPSGSM-E (ANTENNA GPS-GSM CONNETTORE SMA )
  • POWER 12 V 300mA
The GSM function like send SMS work but when I try to use the example in GPS library (BETA_GSM_GPRS_GPS_908_IDE100_v301.zip [BETA VER.] GSM GPRS GPS Shield, SIM908, IDE 1.00, Version 3.01 on google code ) don't work:
I link the part of example code:
#include "SIM900.h"
#include <SoftwareSerial.h>
//#include "inetGSM.h"
//#include "sms.h"
//#include "call.h"
#include "gps.h"
//To change pins for Software Serial, use the two lines in GSM.cpp.
//GSM Shield for Arduino
//www.open-electronics.org
//this code is based on the example of Arduino Labs.
//Simple sketch to start a connection as client.
//InetGSM inet;
//CallGSM call;
//SMSGSM sms;
GPSGSM gps;
char lon[10];
char lat[10];
char alt[10];
char time[15];
char vel[10];
char msg1[5];
char msg2[5];
char stat;
char inSerial[20];
int i=0;
boolean started=false;
//Serial connection.
Serial.println("GSM Shield testing.");
//Start configuration of shield with baudrate.
//For http uses is raccomanded to use 4800 or slower.
if (gsm.begin(2400)){
Serial.println("\nstatus=READY");
gsm.forceON(); //To ensure that SIM908 is not only in charge mode
started=true;
else Serial.println("\nstatus=IDLE");
if(started){
//GPS attach
if (gps.attachGPS())
Serial.println("status=GPSON");
else Serial.println("status=ERROR");
delay(20000); //Time for fixing
stat=gps.getStat();
if(stat==1)
Serial.println("NOT FIXED");
else if(stat==0)
Serial.println("GPS OFF");
else if(stat==2)
Serial.println("2D FIXED");
else if(stat==3)
Serial.println("3D FIXED");
delay(5000);
//Get data from GPS
gps.getPar(lon,lat,alt,time,vel);
Serial.println(lon);
Serial.println(lat);
Serial.println(alt);
Serial.println(time);
Serial.println(vel);
... etc etc
The output is:
DB:CORRECT BR
GSM Shield testing.
DB:ELSE
DB:ELSE
DB:ELSE
DB:CORRECT BR
status=READY
status=GPSON
GPS OFF
I tried to increase the time of wait but nothing. The GPS antenna is in open space outside but nothing
Can you guys help me?
Tnks
It can take up to 3 minutes for a first fix with some GPS devices, so waiting 20 seconds won't give it time to fix. Just as a test try delay(240000); which will instruct it to wait 4 minutes.
I tried delay(240000); but nothing
