GPS Sirfstar III garbage data
I would like some help figuring out why the arduino is not displaying the correct GPS data. The GPS has a fix and seems to be sending some data. Please look at the screenshot below.
The GPS is connected to the arduino like this...
GPS to Arduino
GND ---- GND
5V ------ 5V
RX ------ Pin 3
TX ------- Pin 2
GND ----- GND (digital side)
This source code mentions a powerpin. Does anyone know how this powerpin is set up?
// A simple sketch to read GPS data and parse the $GPRMC string
// see http://www.ladyada.net/make/gpsshield for more info
#include <AFSoftSerial.h>
AFSoftSerial mySerial =  AFSoftSerial(2, 3);
#define powerpin 4
#define GPSRATE 4800
//#define GPSRATE 38400
// GPS parser for 406a
#define BUFFSIZ 90 // plenty big
char buffer[BUFFSIZ];
char *parseptr;
char buffidx;
uint8_t hour, minute, second, year, month, date;
uint32_t latitude, longitude;
uint8_t groundspeed, trackangle;
char latdir, longdir;
char status;
  if (powerpin) {
    pinMode(powerpin, OUTPUT);
  pinMode(13, OUTPUT);
  Serial.begin(GPSRATE);
  mySerial.begin(GPSRATE);
  // prints title with ending line break
  Serial.println("GPS parser");
   digitalWrite(powerpin, LOW);         // pull low to turn on!
  uint32_t tmp;
  //Serial.print("\n\rread: ");
  readline();
  // check if $GPRMC (global positioning fixed data)
  if (strncmp(buffer, "$GPRMC",6) == 0) {
    // hhmmss time data
    parseptr = buffer+7;
    tmp = parsedecimal(parseptr);
    hour = tmp / 10000;
    minute = (tmp / 100) % 100;
    second = tmp % 100;
    parseptr = strchr(parseptr, ',') + 1;
    status = parseptr[0];
    parseptr += 2;
    // grab latitude & long data
    // latitude
    latitude = parsedecimal(parseptr);
    if (latitude != 0) {
      latitude *= 10000;
      parseptr = strchr(parseptr, '.')+1;
      latitude += parsedecimal(parseptr);
    // read latitude N/S data
    if (parseptr[0] != ',') {
      latdir = parseptr[0];
    //Serial.println(latdir);
    // longitude
    parseptr = strchr(parseptr, ',')+1;
    longitude = parsedecimal(parseptr);
    if (longitude != 0) {
      longitude *= 10000;
      longitude += parsedecimal(parseptr);
    // read longitude E/W data
      longdir = parseptr[0];
    // groundspeed
    groundspeed = parsedecimal(parseptr);
    // track angle
    trackangle = parsedecimal(parseptr);
    // date
    date = tmp / 10000;
    month = (tmp / 100) % 100;
    year = tmp % 100;
    Serial.print("\nTime: ");
    Serial.print(hour, DEC); Serial.print(':');
    Serial.print(minute, DEC); Serial.print(':');
    Serial.println(second, DEC);
    Serial.print("Date: ");
    Serial.print(month, DEC); Serial.println(char(34));
    Serial.print(date, DEC); Serial.println(char(34));
    Serial.println(year, DEC);
    Serial.print("Lat: ");
    if (latdir == 'N')
       Serial.print('+');
    else if (latdir == 'S')
       Serial.print('-');
    Serial.print(latitude/1000000, DEC); Serial.print('°', BYTE); Serial.print(' ');
    Serial.print((latitude/10000)%100, DEC); Serial.println(char(34)); Serial.print(' ');
    Serial.print((latitude%10000)*6/1000, DEC); Serial.print('.');
    Serial.print(((latitude%10000)*6/10)%100, DEC); Serial.println(char(34));
    Serial.print("Long: ");
    if (longdir == 'E')
       Serial.print('+');
    else if (longdir == 'W')
       Serial.print('-');
    Serial.print(longitude/1000000, DEC); Serial.print('°', BYTE); Serial.print(' ');
    Serial.print((longitude/10000)%100, DEC); Serial.println(char(34)); Serial.print(' ');
    Serial.print((longitude%10000)*6/1000, DEC); Serial.print('.');
    Serial.print(((longitude%10000)*6/10)%100, DEC); Serial.println(char(34));
  //Serial.println(buffer);
uint32_t parsedecimal(char *str) {
  uint32_t d = 0;
  while (str[0] != 0) {
   if ((str[0] > '9') || (str[0] < '0'))
     return d;
   d *= 10;
   d += str[0] - '0';
   str++;
  return d;
void readline(void) {
  char c;
  buffidx = 0; // start at begninning
  while (1) {
      c=mySerial.read();
      if (c == -1)
        continue;
      Serial.print(c);
      if (c == '\n')
        continue;
      if ((buffidx == BUFFSIZ-1) || (c == '\r')) {
        buffer[buffidx] = 0;
        return;
      buffer[buffidx++]= c;
the powerpin its to turn on the module when it goes LOW...
I see the code and I think you have the pin inverted...pin 2 TX and pin 3 is RX....
It should be:
AFSoftSerial mySerial = AFSoftSerial(3, 2);
I think...check that...
I tried switching the pins in the sketch and this is what is displayed in the serial window.
Should I make pin 4 control whether the 5 volts reaches the GPS? I'm kind of new to the arduino, do you mean a pull down resistor configuration? Arduino Tutorial - Lesson 5
But what GPS module you are using? What its the default speed rate for that module?
The module is some type of Sirf star III. It does not look the modules on sparkfun.com or ladyada's store. I removed it from a Haicom HI-701.
The specs are at the bottom of the page:
http://www.easydevices.co.uk/pp/Car_Kits/GPS_Mounts/ASUS_A600_CAR_HOLDER_WITH_BUILT_IN_GPS.html
That's the sort of garbled output I receive when I am using the wrong baud rate. Try the others and see what happens. Maybe the GPS module is running at 9600bps rather than 4800?
I'd start by writing a very simple sketch to write the incomming data to the debug terminal and get rid of everything else till you get that working.
