GPS sketch Works on UNO not on Mega
I have the tinyGPS examples working fine with my UNO
but they do not read back GPS info when compiled and loaded to the MEGA
the header line prints to the serial monitor fine but no GPS data
the sketch specifies pin 2 and 3 as the txd and rxd
Does the mega assign pins differently ?
I have changed the baud to 9600 (what my GPS uses)
I have tried many different pins on the Mega but nothing
The other example sketches are the same: UNO yes, Mega no
I think it has to do with not getting the serial from the GPS as the rest of the sketch seems to work
(for example I get the 'header' print out in the serial monitor -- just no lat long etc -- mostly **** or 0
e(ta change xxx to ****)
Here is the slightly modified example code from tinyGPS (unmodified code doesn't work either on mega)
#include <SoftwareSerial.h>
#include <TinyGPS.h>
/* This sample code demonstrates the normal use of a TinyGPS object.
   It requires the use of SoftwareSerial, and assumes that you have a
   4800-baud serial GPS device hooked up on pins 3(rx) and 4(tx).
TinyGPS gps;
SoftwareSerial ss(2, 3);
static void gpsdump(TinyGPS &gps);
static bool feedgps();
static void print_float(float val, float invalid, int len, int prec);
static void print_int(unsigned long val, unsigned long invalid, int len);
static void print_date(TinyGPS &gps);
static void print_str(const char *str, int len);
  ss.begin(9600);
  Serial.print("Testing TinyGPS library v. "); Serial.println(TinyGPS::library_version());
  Serial.println("by Mikal Hart");
  Serial.print("Sizeof(gpsobject) = "); Serial.println(sizeof(TinyGPS));
  Serial.println("Sats HDOP Latitude Longitude Fix  Date       Time       Date Alt     Course Speed Card  Distance Course Card  Chars Sentences Checksum");
  Serial.println("          (deg)    (deg)     Age                        Age  (m)     --- from GPS ----  ---- to London  ----  RX    RX        Fail");
  Serial.println("--------------------------------------------------------------------------------------------------------------------------------------");
  bool newdata = false;
  unsigned long start = millis();
  // Every second we print an update
  while (millis() - start < 1000)
    if (feedgps())
      newdata = true;
  gpsdump(gps);
  float flat, flon;
  unsigned long age, date, time, chars = 0;
  unsigned short sentences = 0, failed = 0;
  static const float LONDON_LAT = 51.508131, LONDON_LON = -0.128002;
  print_int(gps.satellites(), TinyGPS::GPS_INVALID_SATELLITES, 5);
  print_int(gps.hdop(), TinyGPS::GPS_INVALID_HDOP, 5);
  gps.f_get_position(&flat, &flon, &age);
  print_float(flat, TinyGPS::GPS_INVALID_F_ANGLE, 9, 5);
  print_float(flon, TinyGPS::GPS_INVALID_F_ANGLE, 10, 5);
  print_int(age, TinyGPS::GPS_INVALID_AGE, 5);
  print_date(gps);
  print_float(gps.f_altitude(), TinyGPS::GPS_INVALID_F_ALTITUDE, 8, 2);
  print_float(gps.f_course(), TinyGPS::GPS_INVALID_F_ANGLE, 7, 2);
  print_float(gps.f_speed_kmph(), TinyGPS::GPS_INVALID_F_SPEED, 6, 2);
  print_str(gps.f_course() == TinyGPS::GPS_INVALID_F_ANGLE ? "*** " : TinyGPS::cardinal(gps.f_course()), 6);
  print_int(flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0UL : (unsigned long)TinyGPS::distance_between(flat, flon, LONDON_LAT, LONDON_LON) / 1000, 0xFFFFFFFF, 9);
  print_float(flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : TinyGPS::course_to(flat, flon, 51.508131, -0.128002), TinyGPS::GPS_INVALID_F_ANGLE, 7, 2);
  print_str(flat == TinyGPS::GPS_INVALID_F_ANGLE ? "*** " : TinyGPS::cardinal(TinyGPS::course_to(flat, flon, LONDON_LAT, LONDON_LON)), 6);
  gps.stats(&chars, &sentences, &failed);
  print_int(chars, 0xFFFFFFFF, 6);
  print_int(sentences, 0xFFFFFFFF, 10);
  print_int(failed, 0xFFFFFFFF, 9);
  char sz[32];
  if (val == invalid)
    strcpy(sz, "*******");
    sprintf(sz, "%ld", val);
  sz[len] = 0;
  for (int i=strlen(sz); i<len; ++i)
    sz[i] = ' ';
  if (len > 0)
    sz[len-1] = ' ';
  Serial.print(sz);
  feedgps();
  char sz[32];
  if (val == invalid)
    sz[len] = 0;
        if (len > 0)
          sz[len-1] = ' ';
    for (int i=7; i<len; ++i)
        sz[i] = ' ';
    Serial.print(sz);
    Serial.print(val, prec);
    int vi = abs((int)val);
    int flen = prec + (val < 0.0 ? 2 : 1);
    flen += vi >= 1000 ? 4 : vi >= 100 ? 3 : vi >= 10 ? 2 : 1;
    for (int i=flen; i<len; ++i)
      Serial.print(" ");
  feedgps();
  int year;
  byte month, day, hour, minute, second, hundredths;
  unsigned long age;
  gps.crack_datetime(&year, &month, &day, &hour, &minute, &second, &hundredths, &age);
  if (age == TinyGPS::GPS_INVALID_AGE)
    Serial.print("*******    *******    ");
    char sz[32];
    sprintf(sz, "%02d/%02d/%02d %02d:%02d:%02d   ",
        month, day, year, hour, minute, second);
    Serial.print(sz);
  feedgps();
  int slen = strlen(str);
  for (int i=0; i<len; ++i)
    Serial.print(i<slen ? str[i] : ' ');
  feedgps();
  while (ss.available())
    if (gps.encode(ss.read()))
      return true;
  return false;
You have 4 hardware serial ports. Why do you (think you) need to use software serial, too?
Not sure why, Paul
but it was written that way
are you suggesting on the mega to use one of the other 4 ports
I think I tried that but it didn't work (or more likely my code was bad :smiley:
can you point me in the right direction ?
OK I give
2 hours and still don't see the code
What code don't you see?
It helps to show what you see in the serial monitor. For example the sketch prints:
Do you see that? And what else?
Since your example doesn't compile with the TinyGPS library it would be helpful to post a link to that.
Not all pins on the Mega and Mega 2560 support change interrupts, so only the following can be used for RX: 10, 11, 12, 13, 50, 51, 52, 53, 62, 63, 64, 65, 66, 67, 68, 69
You could replace that by Serial1 (for example) by changing the 3 lines that refer to "ss" (and deleting the above line).
when I replace it with
Serial1 (18, 19)
I get this error message
expected constructor, destructor, or type conversion before "(" token
On a 2560:
Serial0 is pins 0 (rx) & 1 (tx)
Serial1 is pins 18 (rx) & 19 (tx)
Serial2 is pins 16 (rx) & 17 (tx)
Serial3 is pins 14 (rx) & 15 (tx)
You refer to those ports as seen on page Serial - Arduino Reference
You do not specify the pin numbers, the arduino already knows what pin number they are.
I'm berring he'll have to fix TinyGPS.h to not use softserial as well, but to use one of the hardware ports.
SolarPanels:
Delete that line.
IT'S WORKING !!!
The sketch is too long to post
But I changed this in the beginning: Added "Serial1.begin(9600)
and changed a loop near the end to look at Serial1
Serial1.begin(9600);
And changed this near the end
Serial.print(i<slen ? str : ' ');
  • feedgps();*
    _ while (Serial1.available())_
    _ if (gps.encode(Serial1.read()))_
  • return true;*
  • return false;*
    [/quote]
Wish I'd read this a couple of weeks ago.
I had the same problem, trying to use the TinyGPS examples on my Mega 2560.
I eventually figured out to use the hardware Serial1 on the Mega 2560 and got things working.
But didn't know why the example supplied didn't work!
The post, above, from dxw00d explains things!
Wish there were comments explaining this included in the example sketches, to avoid such problems for future users!
eg. state that 2560 should use different pins for softwareserial, not (2,3), or else should use hardware serial.
regards,
The Adafruit library is a better Lib, I think and it also has descriptions of pins for a mega and a "How To" as well. Adafruit usually has good working libs and examples.
In my tender experience. I bought one of those 1.8" tft lcd's from them and besides not having the color orange.. yet Was an easy set of examples on how to use a GLCD...
Doc
if i use hardware serial, do i need to change to UART mode?
gunamoi1:
regards,
is this the right connection??
Is this a cross-post from http://arduino.cc/forum/index.php/topic,118312 ?
Can you stick to one thread please? It's really frustrating when the same question/photos are posted in multiple threads. It's hard to know which one to respond to.
