Hello,
First of all, thanks for the tinygps library to the author.
I bought 2 SKM53 from ebay
=> 1 is on my MEGA (using hardware serial1)
=> 1 on Pro mini 5V (using software serial)
They both do the same thing when I use the example from tinygps library (and also tinygps++)
After the first fix, it seems to work OK for ~20sec
After that every new line printed by println are the same for LONG LAT ALT they do not change at all.
The other lines changes (age increase to ~400/500, statelite update, time update; check sum update also (don't increase))
I am moving in my garden with my laptop to check is lat + lon are changing and nothing happen.
I dont get it, I need help
I don't post any code as it is exactly the code from the examples ! (except baud rate for skm53 is 9600 and on the mega the soft => hard serial change)
I did not find anyone descibing this problem or maybe is it somewhere in the middle of all the ppl having wiring issues !
Best regards
