Hello I have been making a gps speedometer with a small oled for quite some time now. I have code but it updates at terribly slow pace. If anyone has any suggestions on how i could get the gps to update my speed faster it would be much appreciated.
//Connections:
//GPS TX -> Arduino 0 (disconnect to upload this sketch)
// GPS RX -> Arduino 1
//Screen SDA -> Arduino A4
//Screen SCL -> Arduino A5
#include <NMEAGPS.h>
NMEAGPS gps;
gps_fix fix;
#include "U8glib.h"
U8GLIB_SSD1306_128X64 u8g(U8G_I2C_OPT_DEV_0|U8G_I2C_OPT_NO_ACK|U8G_I2C_OPT_FAST); // Fast I2C / TWI
#define gpsPort Serial
u8g.setColorIndex(1);
gpsPort.begin(9600);
gps.send_P( &gpsPort, F("PUBX,40,GLL,0,0,0,0,0,0") );
gps.send_P( &gpsPort, F("PUBX,40,GSV,0,0,0,0,0,0") );
gps.send_P( &gpsPort, F("PUBX,40,GSA,0,0,0,0,0,0") );
gps.send_P( &gpsPort, F("PUBX,40,VTG,0,0,0,0,0,0") );
gps.send_P( &gpsPort, F("PUBX,40,ZDA,0,0,0,0,0,0") );
gps.send_P( &gpsPort, F("PUBX,40,RMC,0,1,0,0,0,0") );
gps.send_P( &gpsPort, F("PUBX,40,GGA,0,1,0,0,0,0") );
char spinner( uint8_t pos )
static const char spinnerChars[] PROGMEM = "/-\\|"; // saves RAM!
return (char) pgm_read_byte( &spinnerChars[ pos % 4 ] ); // ...but requires special read
uint16_t kph = 0;
uint16_t lastScreenUpdate = 0;
byte screenRefreshes = 0;
byte gpsUpdates = 0;
uint16_t now = millis();
if ( gps.available( gpsPort ) ) {
fix = gps.read();
gpsUpdates++;
if (fix.valid.speed)
kph = (((uint32_t) fix.spd.whole) * 1852) / 1000; // knots to kph, integer math
kph = 0;
lastScreenUpdate = now - 102; // force a redraw
if ( now - lastScreenUpdate > 101 ) {
updateScreen();
lastScreenUpdate = now;
screenRefreshes++;
void draw() {
//u8g.setScale2x2(); don't do this!
u8g.setFont(u8g_font_courB24);
u8g.setPrintPos( 36, 45 );
if (kph < 100) // alternative to sprintf, just print leading spaces
u8g.write( ' ' );
if (kph < 10)
u8g.write( ' ' );
u8g.print( kph );
//u8g.undoScale();
u8g.setFont(u8g_font_fur11);
u8g.setPrintPos( 2, 12 );
u8g.write( spinner( screenRefreshes ) );
u8g.write( ' ' );
u8g.write( spinner( gpsUpdates ) );
u8g.write( ' ' );
if (!fix.valid.satellites || (fix.satellites < 10))
u8g.write( ' ' );
if (fix.valid.satellites)
u8g.print( fix.satellites );
u8g.write( ' ' );
void updateScreen() {
u8g.firstPage();
do {
draw();
} while( u8g.nextPage() );
