The Radiometrix string looks like this: "000000,100#v,999tl<hheIRd$Irrrerrrrr%rrrerrrrr -----" (correct transmission shown in red text).
I suspect that the jumble of text that follows the correct transmission has its roots in a buffer problem, but I don't know enough to test this by modifying the programme.
The programme and hardware can produce a coherent serial print string - the difficulty seems to be getting the whole string through the radiometrix transmitter to the receiver (DI-fldigi).
Or even to read the posts at the top of the forum that say "Read me before posting". It's clear that you didn't because, if you had, you'd know that you needed to post you f**king code.
I didn't include the code because I thought, quite wrongly, that maybe I had given enough to prompt a general steer - which I suppose you did.
I am using a Arduino Uno with a Radiometrix NTX2B-FA, 434.30. The Radiometrix circuit uses 2x4k4 and one 47k resistors to get the necessary RTTY shift. As I said earlier, the transmission gets through, but only for a short section of useful text followed by gibberish.
However, this time I have attached the programme (GPS_Radiometrix1.txt).
Please accept my apologies for causing annoyance, and again, thanks for your very direct and chastening response.
So, first thing we do is wait for any pending data to be sent. Why? Are you sending data TO the GPS?
int i = 0;
unsigned long start = millis();
while ((i<60) && ((millis() - start) < 2000) )
if (Serial.available()) {
char c = Serial.read();
tgps.encode(c);
Since you have hardcoded i to 0, is there any point in testing it in the while statement?
Listening for data for two seconds, when GPSs typically send data once per second seems pointless. Ignoring whether the encode() method returned true or false is also silly.
