gps.TinyGPS::satellites' does not have class type
hi there, i try running my program,but it still have a problem on it.ive also install tinyGps Library,but the problem like this appears.
Arduino: 1.8.15 (Windows Store 1.8.49.0) (Windows 10), Board: "WEMOS LOLIN32, 80MHz, Default, 240MHz (WiFi/BT), 921600"
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\ridho\Documents\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\ridho\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\ridho\Documents\Arduino\libraries -fqbn=esp32:esp32:lolin32:FlashFreq=80,PartitionScheme=default,CPUFreq=240,UploadSpeed=921600 -ide-version=10815 -build-path C:\Users\ridho\AppData\Local\Temp\arduino_build_571234 -warnings=none -build-cache C:\Users\ridho\AppData\Local\Temp\arduino_cache_934408 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-1.22.0-97-gc752ad5-5.2.0.path=C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.esptool_py.path=C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.esptool_py-3.0.0.path=C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.mkspiffs.path=C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\mkspiffs\0.2.3 -verbose C:\Users\ridho\Documents\Arduino\gps_tracker\gps_tracker.ino
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\arduino-builder -compile -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\ridho\Documents\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\ridho\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\ridho\Documents\Arduino\libraries -fqbn=esp32:esp32:lolin32:FlashFreq=80,PartitionScheme=default,CPUFreq=240,UploadSpeed=921600 -ide-version=10815 -build-path C:\Users\ridho\AppData\Local\Temp\arduino_build_571234 -warnings=none -build-cache C:\Users\ridho\AppData\Local\Temp\arduino_cache_934408 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-1.22.0-97-gc752ad5-5.2.0.path=C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.esptool_py.path=C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.esptool_py-3.0.0.path=C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.mkspiffs.path=C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\mkspiffs\0.2.3 -verbose C:\Users\ridho\Documents\Arduino\gps_tracker\gps_tracker.ino
Using board 'lolin32' from platform in folder: C:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6
Using core 'esp32' from platform in folder: C:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6
cmd /c if exist "C:\Users\ridho\Documents\Arduino\gps_tracker\partitions.csv" copy /y "C:\Users\ridho\Documents\Arduino\gps_tracker\partitions.csv" "C:\Users\ridho\AppData\Local\Temp\arduino_build_571234\partitions.csv"
cmd /c if not exist "C:\Users\ridho\AppData\Local\Temp\arduino_build_571234\partitions.csv" copy "C:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\tools\partitions\default.csv" "C:\Users\ridho\AppData\Local\Temp\arduino_build_571234\partitions.csv"
Detecting libraries used...
gps_tracker:90:23: error: 'class TinyGPS' has no member named 'location'
 display.print(gps.location.lng(),6);
gps_tracker:95:19: error: 'gps.TinyGPS::speed' does not have class type
 display.print(gps.speed.kmph());
gps_tracker:107:19: error: 'gps.TinyGPS::altitude' does not have class type
 display.print(gps.altitude.meters(), 0);
Multiple libraries were found for "Adafruit_SSD1306.h"
Used: C:\Users\ridho\Documents\Arduino\libraries\Adafruit_SSD1306
Not used: C:\Users\ridho\Documents\Arduino\libraries\Adafruit_SSD1306_Wemos_Mini_OLED
Not used: C:\Users\ridho\Documents\Arduino\libraries\Adafruit_SSD1306-master
Using library Wire at version 1.0.1 in folder: C:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\Wire
Using library Adafruit_SSD1306 at version 2.4.4 in folder: C:\Users\ridho\Documents\Arduino\libraries\Adafruit_SSD1306
Using library arduino_696289 at version 1.10.10 in folder: C:\Users\ridho\Documents\Arduino\libraries\arduino_696289
Using library SPI at version 1.0 in folder: C:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\SPI
Using library TinyGPS at version 13.0.0 in folder: C:\Users\ridho\Documents\Arduino\libraries\TinyGPS
Using library Adafruit_BusIO at version 1.7.2 in folder: C:\Users\ridho\Documents\Arduino\libraries\Adafruit_BusIO
exit status 1
'gps.TinyGPS::satellites' does not have class type
i hope the solution for this problem.should i uninstall tinnylibrary and install it again?
megantara
Your post was MOVED to its current location as it is more suitable.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
Looks like you are using features of the "TinyGPS++" library but installed the "TinyGPS" library.
yap..youre right..but i dont find Tinygps ++ library?
You probably need to seach for it, try a Google search on;
'Arduino Tinygps++ library'
Google tells me it is at:
http://arduiniana.org/libraries/tinygpsplus/
thanks broww!!!mantab jiwa!!have a nice day!!
yoi brow!!!have a nice day
