gps track
Hi, can you tell me, how I can connect gps bee and gprs shield. What pins I need to use, and can you help with the code? I use arduino mega 2560
That "link" is broken.
and gprs shield.
So is that one.
You seem to not understand the concept of a shield. IT defines the pins it uses.
$200 an hour, with a 5 hour minimum.
Links to the hardware you are using?
I buy bandwidth at so much a month. I'm not going to waste nearly 2 megabytes downloading your photo.
And I asked for links to the hardware, not a photo. If you can't provide links then I can't help you.
I try to use this code, but i haven't receive data again:
Are you using Serial to talk to the GPS or the PC? Yes is the wrong answer. So is both.
