GPS TRACKER with GSM
I want do project which is use GPS & GSM module use arduino take data from GPS(NEO6MV2) and send by GSM(SIM800L GSM ) to my phone I 'am use separate GPS module I try this code but still have
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
double latitude, longitude;
TinyGPSPlus gps;
SoftwareSerial SIM800L(7,8);
SoftwareSerial gps_Serial(2,3);
String response;
int lastStringLength = response.length();
String link;
  Serial.println("GPS Mulai");
    SIM800L.begin(9600);
    SIM800L.println("AT+CMGF=1");
    Serial.println("SIM800L started at 9600");
    Serial.println("Setup Complete! SIM800L is Ready!");
    SIM800L.println("AT+CNMI=2,2,0,0,0");
  if (SIM800L.available()>0){
      response = SIM800L.readStringUntil('\n');
  if(lastStringLength != response.length()){
     // GPS();
      //Perintah ON
      if(response.indexOf("ON") == 4){
          SIM800L.println("AT+CMGF=1");    //Sets the GSM Module in Text Mode
          delay(1000);  // Delay of 1000 milli seconds or 1 second
          SIM800L.println("AT+CMGS=\"082232949301\"\r"); // Replace x with mobile number
          SIM800L.println(link);// The SMS text you want to send
          delay(100);
          SIM800L.println((char)26);// ASCII code of CTRL+Z
      }GPS();
void GPS(){
  if(Serial.available()) {
    gps.encode(Serial.read());
  if(gps.location.isValid()) {
    latitude = gps.location.lat();
    longitude = gps.location.lng();
    link = "www.google.com/maps/place/" + String(latitude, 6) + "," + String(longitude, 6) ;
    Serial.println(link);
I just receive a blank text.
you need to be outdoors for gps to work properly, have you tried sending a pre defined sms to check if the gsm module does the sending? to begin with?
      }GPS();
Nothing EVER follows a } on the same line (except for a ; at the end of a class/struct definition.
Your code layout sucks. Tools + Auto Format could fix that in a heartbeat.
The encode() method returns a very important piece of information that you just ignore. Why?
I'm done reading your code until you DO use the value that encode() returns.
I will observe, though, that you only send a text message once when you receive a message containing "ON". That is NOT what I would expect sending "ON" to do.
