Here is my code, the result is a .txt file on the sd that has no text or anything in it.
// Based off of Finding Your Way With GPS from the Make Magazine #35
//SD Tracker for Adafruit Ultimate GPS Breakout v3
//Using a SeeedStudio SD card sheild v3.1
//Breakout Pin------Arduino pin
// TX ------ D2
// RX ------ D3
// VIN ------ 5V
// GND ------ GND
#include <SPI.h> //include librarys
#include <SD.h>
#include <SoftwareSerial.h>
#include <TinyGPS++.h>
#define RXPin 2 //define pins
#define TXPin 3
#define GPSBaud 4800 //define baud rates
#define ConsoleBaud 115200
SoftwareSerial ss(RXPin, TXPin); // The serial connection to the GPS device
TinyGPSPlus gps; // The TinyGPS++ object
const int chipSelect = 10; //Setup the SD card chip select
File myFile; //Make a file on the SD card
/* make sure that the default chip select pin is set to
output, even if you don't use it:*/
pinMode(SS, OUTPUT);
if (!SD.begin(chipSelect)) { // see if the card is present and can be initialized:
return;
myFile = SD.open("Trip1.txt", FILE_WRITE);
//turn on next line for debuging
//Serial.begin(ConsoleBaud);
ss.begin(GPSBaud);
myFile.println("GPS Tracker");
myFile.println("A simple tracker using TinyGPS++, SD, SPI, and Software Serial");
myFile.println("by Alexander Pope");
myFile.println();
// if the file opened okay, write to it:
if (myFile) {
// If any characters have arrived from the GPS,
// send them to the TinyGPS++ object
while (ss.available() > 0)
gps.encode(ss.read());
// Let's display the new location and altitude
// whenever either of them have been updated.
if (gps.location.isUpdated() || gps.altitude.isUpdated())
myFile.print("Location: ");
myFile.print(gps.location.lat(), 6);
myFile.print(",");
myFile.print(gps.location.lng(), 6);
myFile.println(" Altitude: ");
myFile.print(gps.altitude.meters());
if (gps.time.isUpdated())
char buf[80];
sprintf(buf, "The time is %02d:%02d:%02d", gps.time.hour(), gps.time.minute(), gps.time.second());
myFile.println(buf);
else{
// open the file. note that only one file can be open at a time,
// so you have to close this one before opening another.
