Gps tracking system by sms
#include <Adafruit_Circuit_Playground.h>
/* #include <Adafruit_CircuitPlayground.h>
#include <Adafruit_Circuit_Playground.h>*/
#include <Adafruit_FONA.h>
#include <LowPower.h>
#include <SoftwareSerial.h>
#define FONA_RX 11;
#define FONA_TX 10;
#define FONA_RST 4S;
SoftwareSerial fonaSS = SoftwareSerial
(FONA_TX, FONA_RX);
SoftwareSerial *fonaSerial = &fonaSS;
const int MOSFET = 13;
const int WakeUp = 2;
char replybuffer[255];
Adafruit_FONA_3G fona = Adafruit_FONA_3G(FONA_RST);
float latitude, longitude, speed_kph, heading, speed_mph, altitude;
unsigned long currentMillis;
unsigned long previousMillis = 0;
unsigned long timer;
unsigned long timer2 = 0;
boolean gps_success;
pinMode(WakeUp, INPUT);
pinMode(MOSFET, OUTPUT);
attachInterrupt(0, TimerReset, RISING);
digitalWrite(MOSFET, LOW);
delay(10000);
LowPower.powerDown(SLEEP_FOREVER, ADC_OFF, BOD_OFF);
while ( timer < 4200000){
if ( timer2 == 0 ){
GetGPS();
WriteSMS();
currentMillis = millis();
timer = timer + (currentMillis - previousMillis);
timer2 = timer2 + (currentMillis - previousMillis);
if ( timer2 > 1800000){
GetGPS();
WriteSMS();
timer2 = 1;
void WriteSMS () {
fonaSS.print("AT+CMGF=1\r");
fonaSS.print("AT+CMGS="+0211977188"\r");
fonaSS.println(latitude, 6);
fonaSS.println(longitude, 6);
fonaSS.print("\r");
fonaSS.println((char)26);
fonaSS.println();
delay(10000);
void GetGPS() {
gps_success = 0;
digitalWrite(MOSFET, HIGH);
fonaSerial->begin(4800);
if (! fona.begin(*fonaSerial)) {
while (1);
fona.enableGPS(true);
while(!gps_success){
delay(2000);
gps_success = fona.getGPS(&latitude, &longitude, &speed_kph, &heading, &altitude);
if (gps_success) {
Serial.print("GPS lat:");
Serial.println(latitude, 6);
Serial.print("GPS long:");
Serial.println(longitude, 6);
void TimerReset() {
timer = 0;
Do you have a question ?
The easier you make it to read and copy the code the more likely it is that you will get help
Please follow the advice given in the link below when posting code , use code tags and post the code here
yes, Arduino ide says that there is expected primary-expression before '(' token
for this line of code softwareSerial fonaSS = SoftwareSerial(FONA_TX, FONA_RX);
#define FONA_RX 11;
#define FONA_TX 10;
Delete the semicolons. Otherwise FONA+RX will be replaced by 11; throughout the code rather than 11 and cause problems
I have fixed all problems now, however, it now says there is an error compiling for board arduino uno
In that case you have not fixed all of the problems
Post your revised code (using code tags) and the full error message copied from the IDE using the "Copy Error messages" button
Arduino: 1.8.13 (Windows 10), Board: "Arduino Uno"
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp: In member function 'void Adafruit_CircuitPlayground::playTone(uint16_t, uint16_t, bool)':
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:215:3: error: 'PLLFRQ' was not declared in this scope
PLLFRQ = (PLLFRQ & 0xCF) | 0x30; // Route PLL to async clk
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:215:3: note: suggested alternative: 'PCIFR'
PCIFR
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:216:3: error: 'TCCR4A' was not declared in this scope
TCCR4A = _BV(COM4A0) | _BV(PWM4A); // Clear on match, PWMA on
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:216:3: note: suggested alternative: 'TCCR0A'
TCCR0A
In file included from c:\program files (x86)\arduino\hardware\tools\avr\avr\include\avr\io.h:99:0,
             from c:\program files (x86)\arduino\hardware\tools\avr\avr\include\avr\pgmspace.h:90,
             from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:28,
             from C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground/Adafruit_Circuit_Playground.h:20,
             from C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:30:
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:216:17: error: 'COM4A0' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:216:17: note: suggested alternative: 'COM0A0'
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:216:31: error: 'PWM4A' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:216:31: note: suggested alternative: 'PWM'
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:217:3: error: 'TCCR4B' was not declared in this scope
TCCR4B = _BV(PWM4X) | scalebits; // PWM invert
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:217:3: note: suggested alternative: 'TCCR0B'
TCCR0B
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:217:17: error: 'PWM4X' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:217:17: note: suggested alternative: 'PWM'
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:218:3: error: 'TCCR4D' was not declared in this scope
TCCR4D = 0; // Fast PWM mode
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:218:3: note: suggested alternative: 'TCCR0A'
TCCR0A
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:219:3: error: 'TCCR4E' was not declared in this scope
TCCR4E = 0; // Not enhanced mode
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:219:3: note: suggested alternative: 'TCCR0A'
TCCR0A
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:220:3: error: 'DT4' was not declared in this scope
DT4 = 0; // No dead time
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:220:3: note: suggested alternative: 'DD4'
DD4
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:226:3: error: 'TC4H' was not declared in this scope
TC4H = hi1;
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:226:3: note: suggested alternative: 'PC4'
TC4H = hi1;
PC4
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:227:3: error: 'OCR4C' was not declared in this scope
OCR4C = lo1; // TOP
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:227:3: note: suggested alternative: 'OCR2A'
OCR4C = lo1; // TOP
OCR2A
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:229:3: error: 'OCR4A' was not declared in this scope
OCR4A = lo2; // 50% duty
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:229:3: note: suggested alternative: 'OCR2A'
OCR2A
Multiple libraries were found for "Adafruit_FONA.h"
Used: C:\Users\lucia\OneDrive\Documents\Arduino\libraries\Adafruit_FONA-master
Not used: C:\Users\lucia\OneDrive\Documents\Arduino\libraries\Adafruit_FONA_Library
exit status 1
Error compiling for board Arduino Nano.
option enabled in File -> Preferences.
#define FONA_RX 11
#define FONA_TX 10
#define FONA_RST 4
SoftwareSerial fonaSS = SoftwareSerial(FONA_TX, FONA_RX);
delay(10000);
if ( timer2 == 0 ){
GetGPS();
WriteSMS();
GetGPS();
WriteSMS();
timer2 = 1;
void WriteSMS () {
fonaSS.print("\r");
fonaSS.println();
delay(10000);
void GetGPS() {
gps_success = 0;
while (1);
delay(2000);
if (gps_success) {
void TimerReset() {
timer = 0;
No more help from me until you post your code in code tags as requested
<#include <Adafruit_Circuit_Playground.h>
#define FONA_RX 11
#define FONA_TX 10
#define FONA_RST 4
delay(10000);
if ( timer2 == 0 ){
GetGPS();
WriteSMS();
GetGPS();
WriteSMS();
timer2 = 1;
void WriteSMS () {
fonaSS.print("\r");
fonaSS.println();
delay(10000);
void GetGPS() {
gps_success = 0;
while (1);
delay(2000);
if (gps_success) {
void TimerReset() {
timer = 0;
Still wrong
Here, let me do it for you
< #include <Adafruit_Circuit_Playground.h>
#define FONA_RX 11
#define FONA_TX 10
#define FONA_RST 4
  delay(10000);
    if ( timer2 == 0 )
      GetGPS();
      WriteSMS();
      GetGPS();
      WriteSMS();
      timer2 = 1;
void WriteSMS ()
  fonaSS.print("AT+CMGS=" + 0211977188"\r");
  fonaSS.print("\r");
  fonaSS.println();
  delay(10000);
void GetGPS()
  gps_success = 0;
    while (1);
  while (!gps_success)
    delay(2000);
    if (gps_success)
void TimerReset()
  timer = 0;
and to help further I have Auto formatted the code in the IDE to make it easier to read and understand
As to the problem, it is because you have the board set to Uno in the IDE
but the Circuit playground is not a Uno
Read this Set Up Arduino IDE | Adafruit Circuit Playground Express | Adafruit Learning System
So how do i change the circuit playground to an arduino?
also it says for this line of code that there is invalid digital in octal constant.
It is already an Arduino bit it uses a different processor than the Uno. You need to install support for it in the IDE following the instructions in the link that I posted
Once you do that then most of the errors will not happen and you can concentrate on any that are left
ok i have now fixed that but now its saying this
Arduino: 1.8.13 (Windows 10), Board: "Adafruit Circuit Playground Express"
F0BC3WXJ0CORE4L:11:10: fatal error: SoftwareSerial.h: No such file or directory
compilation terminated.
exit status 1
Arduino ide says my code is wrong and I don't know what to do. I am following the great Scotts youtube tutorial. I used the exact same code but it says it's wrong. Here is the code, if anyone could help me that would be much appreciated.
#define FONA_RX 11
#define FONA_TX 10
#define FONA_RST 4
  delay(10000);
    if ( timer2 == 0 )
      GetGPS();
      WriteSMS();
      GetGPS();
      WriteSMS();
      timer2 = 1;
void WriteSMS ()
  fonaSS.print("AT+CMGS="+64211977188"\does this work");
  fonaSS.print("\r");
  fonaSS.println();
  delay(10000);
void GetGPS()
  gps_success = 0;
    while (1);
    delay(2000);
    if (gps_success)
void TimerReset()
  timer = 0;
Preformatted text`
Duplicate topics merged
Cross posting is against the rules of this forum. It wastes time so please do not do it
Sorry about that i just desperately need to fix this as soon as possible.
i put code tags now. Sorry to be pushy but i need this finished soon.
#define FONA_RX 11
#define FONA_TX 10
#define FONA_RST 4
  delay(10000);
    if ( timer2 == 0 )
      GetGPS();
      WriteSMS();
      GetGPS();
      WriteSMS();
      timer2 = 1;
void WriteSMS ()
  fonaSS.print("\r");
  fonaSS.println();
  delay(10000);
void GetGPS()
  gps_success = 0;
    while (1);
    delay(2000);
    if (gps_success)
void TimerReset()
  timer = 0;
