GPS-view output on serial monitor or plotter
A common method of easily checking that a GPS module is outputting serial data is the serial passthrough which displays on the serial monitor each byte available in the serial buffer:
while (Serial.available()) Serial.write(Serial.read()); //displays ASCII characters
Another method is to use the serial plotter to trace the status of the GPS TX pin:
Serial.println(digitalRead(receivingPin)); //plots 1 or 0
Maybe the plotter method is just a curiosity but I think it's of interest and instructive.
The sketch:
/*GPS pass thru two ways;
   uses one of two methods:
   1. traces status of GPS TX pin on serial plotter
   or
   2. displays GPS output on serial monitor as ACSII sentences
const int  receivingPin = 0;    // GPS TX connected to this digital pin
  // initialize the receiving pin as input:
  pinMode(receivingPin, INPUT);
  // initialize serial communication:
  //comment out the method you do NOT want to use
  //use this method to trace status of GPS TX pin on plotter
  //use this method to display GPS sentences on monitor
