Does anybody know a GPS that can output pseudo range easily compatible with Arduino?
Unfortunately the NEO-6m doesn't output pseudo range normally, and it'll be probably be difficulty to program RTKLIB to get it. Any suggestions would be appreciated.
I don't think standard NMEA allows for it. There's a GST sentence "GPS pseudorange noise statistics", doesn't sound quite what you want. A proprietry sentence may be available, that's something the documentation might mention.
Hopefully someone knows something, but Google is more likely to that forum members...
For that, you need an RTK precision GPS, to measure 3D positions to cm accuracy. Can be done using a laptop and a couple of RTK boards (one as the base station and one as the position sensor).
I am not aware that there is a cunning wheeze way of using the raw data from the GPS internals to produce any significant increase in precision over the normal +/- 5m or so.
If there was there would be no need for the significant extra costs of precision\differential GPS and there would be many Arduino libraries in existance already.
Maybe not "cunning", but with a couple of RTK receivers and a laptop, amateurs can and do get about 2 cm accuracy with the GPS system.
Not too long ago I saw an example of someone who used such a system to produce a wire frame model of an automobile, but a few minutes of searching failed to turn up that example. I think it was on a German blog.
