When I use TinyGPS++ library example code, the gps works as expected and returns data.
#include <TinyGPS++.h>
TinyGPSPlus gps;
Serial.begin(9600); // connect serial
Serial1.begin(9600); // connect gps sensor
while (Serial2.available()) // check for gps data
if (gps.encode(Serial2.read())) // encode gps data
Serial.print("SATS: ");
Serial.println(gps.satellites.value());
Serial.print("LAT: ");
Serial.println(gps.location.lat(), 6);
Serial.print("LONG: ");
Serial.printl n(gps.location.lng(), 6);
Serial.print("ALT: ");
Serial.println(gps.altitude.meters());
Serial.print("SPEED: ");
Serial.println(gps.speed.mps());
I have written a code which reads bmp390 sensor and gps data and logs it to an SD card as well as sends telemetery with RF module attached to Serial2 .But when I use the library to get data like below in a string (gpsdata), the if condition isn't satisfied and gpsdata string remains empty. Also, the connections are correct since I checked with library example code and it worked fine.
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include "Adafruit_BMP3XX.h"
#include <SPI.h>
#include <SD.h>
File myFile;
float SEALEVELPRESSURE_HPA,b;
int count=0;
String gpsdata,a;
TinyGPSPlus gps;
Adafruit_BMP3XX bmp;
Serial2.begin(9600);
SD.begin(10);
Serial.println("Adafruit BMP388 / BMP390 test");
if (!bmp.begin_I2C())
Serial.println("Could not find a valid BMP3 sensor, check wiring!");
Serial1.println("Could not find a valid BMP3 sensor, check wiring!");
while (1);
// Set up oversampling and filter initialization
bmp.setTemperatureOversampling(BMP3_OVERSAMPLING_8X);
bmp.setPressureOversampling(BMP3_OVERSAMPLING_4X);
bmp.setIIRFilterCoeff(BMP3_IIR_FILTER_COEFF_3);
bmp.setOutputDataRate(BMP3_ODR_50_HZ);
if (! bmp.performReading()) {
Serial.println("Failed to perform reading :(");
return;
if(count==0)
bmp.pressure;
delay(100);
for(int i=0;i<50;i++)
bmp.performReading();
b+=bmp.pressure;
Serial.println(b);
delay(100);
SEALEVELPRESSURE_HPA=(b/5000);
count=1;
if(gps.encode(Serial2.read()))
gpsdata= String(gps.time.hour()+5) + ':' + String(gps.time.minute()+30) + ':' + String(gps.time.second()) + ',' + String(gps.location.lat(), 4) + ',' + String(gps.location.lat(), 4) + ',' + String(gps.speed.mps()) ;
a= String(bmp.temperature,1) + ',' + String(bmp.pressure,0) + ',' + String(bmp.readAltitude(SEALEVELPRESSURE_HPA),1);
Serial1.println("BMP : ");
Serial1.print(a);
Serial1.println("GPS : ");
Serial1.print(gpsdata);
Serial1.println();
Serial.println("BMP : ");
Serial.print(a);
Serial.println("GPS : ");
Serial.print(gpsdata);
myFile = SD.open("test.txt", FILE_WRITE);
myFile.println("BMP : ");
myFile.print(a);
myFile.println("GPS : ");
myFile.print(gpsdata);
myFile.println();
myFile.close();
gpsdata="";
a="";
delay(200);
