I can't get a readout from my gps-module.
I connected the GPS to an arduino uno and nano without any change in the result
GPSmodule
rx tx gnd vcc
I I I I
tx rc gnd 5v
(1) (0)
#include <string.h>
#include <ctype.h>
int ledPin = 13; // LED test pin
int rxPin = 0; // RX PIN
int txPin = 1; // TX TX
int byteGPS=-1;
char linea[300] = "";
char comandoGPR[7] = "$GPRMC";
int cont=0;
int bien=0;
int conta=0;
int indices[13];
pinMode(ledPin, OUTPUT); // Initialize LED pin
pinMode(rxPin, INPUT);
pinMode(txPin, OUTPUT);
Serial.begin(4800);
for (int i=0;i<300;i++){ // Initialize a buffer for received data
linea*=' ';*
void loop() { - digitalWrite(ledPin, HIGH);*
- byteGPS=Serial.read(); // Read a byte of the serial port*
- if (byteGPS == -1) { // See if the port is empty yet*
- delay(100);*
- } else {*
- // note: there is a potential buffer overflow here!*
- linea[conta]=byteGPS; // If there is serial port data, it is put in the buffer*
- conta++; *
- Serial.print(byteGPS, BYTE);*
- if (byteGPS==13){ // If the received byte is = to 13, end of transmission*
- // note: the actual end of transmission is (i.e. 0x13 0x10)*
- digitalWrite(ledPin, LOW);*
- cont=0;*
- bien=0;*
- // The following for loop starts at 1, because this code is clowny and the first byte is the (0x10) from the previous transmission.*
- for (int i=1;i<7;i++){ // Verifies if the received command starts with $GPR*
_ if (linea*==comandoGPR[i-1]){_
_ bien++;_
_ }_
_ }_
_ if(bien==6){ // If yes, continue and process the data*_
* for (int i=0;i<300;i++){*
_ if (linea*==','){ // check for the position of the "," separator*
* // note: again, there is a potential buffer overflow here!
indices[cont]=i;
cont++;
if (linea==''){ // ... and the ""
indices[12]=i;
cont++;
Serial.println(""); // ... and write to the serial port*
* Serial.println("");
Serial.println("---------------");
for (int i=0;i<12;i++){
switch(i){
case 0 :Serial.print("Time in UTC (HhMmSs): ");break;
case 1 :Serial.print("Status (A=OK,V=KO): ");break;
case 2 :Serial.print("Latitude: ");break;
case 3 :Serial.print("Direction (N/S): ");break;
case 4 :Serial.print("Longitude: ");break;
case 5 :Serial.print("Direction (E/W): ");break;
case 6 :Serial.print("Velocity in knots: ");break;
case 7 :Serial.print("Heading in degrees: ");break;
case 8 :Serial.print("Date UTC (DdMmAa): ");break;
case 9 :Serial.print("Magnetic degrees: ");break;
case 10 :Serial.print("(E/W): ");break;
case 11 :Serial.print("Mode: ");break;
case 12 :Serial.print("Checksum: ");break;
for (int j=indices;j<(indices[i+1]-1);j++){
Serial.print(linea[j+1]);
Serial.println("");
conta=0; // Reset the buffer*
* for (int i=0;i<300;i++){ //
linea=' ';
the code i use is_
