gps
how to send gps data (lat , long) with sim900a using arduino ???
gps code :
#include <SoftwareSerial.h>
SoftwareSerial gpsSerial(10, 11); // RX, TX (TX not used)
const int sentenceSize = 80;
char sentence[sentenceSize];
gpsSerial.begin(9600);
static int i = 0;
if (gpsSerial.available())
char ch = gpsSerial.read();
if (ch != ‘\n’ && i < sentenceSize)
sentence = ch;
  • i++;*
  • else*
    _ sentence = ‘\0’;_
    * i = 0;*
    * displayGPS();*
    void displayGPS()
    * char field[20];*
    * getField(field, 0);*
    * if (strcmp(field, “$GPRMC”) == 0)*
    * Serial.print("Lat: ");*
    * getField(field, 3); // number*
    * Serial.print(field);*
    * getField(field, 4); // N/S*
* Serial.print(" Long: ");*
* getField(field, 5); // number*
* getField(field, 6); // E/W*
* Serial.println(field);*
void getField(char* buffer, int index)
* int sentencePos = 0;*
* int fieldPos = 0;*
* int commaCount = 0;*
* while (sentencePos < sentenceSize)*
* if (sentence[sentencePos] == ‘,’)*
* commaCount ++;*
* sentencePos ++;*
* if (commaCount == index)*
* buffer[fieldPos] = sentence[sentencePos];*
* fieldPos ++;*
* sentencePos ++;*
* buffer[fieldPos] = ‘\0’;*
gsm code :
delay(5000);
Serial.println(“AT”);
Serial.println(“AT+CMGF=1”);
Serial.println("AT+CMGS=“1234567890"”); //CHANGE TO DESTINATION NUMBER
Serial.print(“hi”);
Serial.write(26);
please help me
how can we use this two coddes ( gsm send gps data)
Use code-tags.
Do you understand the code you posted? If not, that’s the first thing you should spend your time on.
lg, couka
Here's a hint:
Read instructions prior to posting.
This is how you mash those two together.
  static int i = 0;
    if (ch != '\n' && i < sentenceSize)
      sentence[i] = ch;
      i++;
      sentence[i] = '\0';
      i = 0;
      displayGPS();
void displayGPS()
  char field[20];
  getField(field, 0);
  if (strcmp(field, "$GPRMC") == 0)
    // Set up the SMS
    Serial.println("AT");
    Serial.println("AT+CMGF=1");
    Serial.println("AT+CMGS=\"1234567890\""); //CHANGE TO DESTINATION NUMBER
    // Send the GPS data
    // End the SMS
    Serial.write(26);
  int fieldPos = 0;
  int commaCount = 0;
    if (sentence[sentencePos] == ',')
      commaCount ++;
      sentencePos ++;
      fieldPos ++;
    sentencePos ++;
  buffer[fieldPos] = '\0';
Here’s a really simple version that uses NeoGPS:
#include "NMEAGPS.h"
NMEAGPS gps;
bool sendEmptyLocations = false; // CHANGE TO true IF YOU WANT TO SEND EMPTY LOCATIONS
  if (gps.available( gpsSerial ))
    gps_fix fix = gps.read();
    if (sendEmptyLocations || fix.valid.location)
      // Set up the SMS
      Serial.print(fix.latitude(),6);
      Serial.println(fix.longitude(),6);
      // End the SMS
      Serial.write(26);
      delay(1000);    // CHANGE TO LONGER INTERVAL
NeoGPS verifies the GPS checksum, so it throws away bad locations caused by data errors. It will also skip sending an empty location when you don’t have good satellite reception.
Cheers,
/dev
hi my name is Peyman . i have a problem in gps ( ublox Neo-6m ). how can we send the gps data ( lat , long ) using sim900a also use i2c gps is on a arduino ( master board) and gsm is on another arduino boaed ( slave board ) . can you help me ????? please send me the codes .......... please please
