gpsbee seeduino stalker
hi all
can someone offer some advice
I have a ublox gps module mounted on bee module that is running off a seeduino stalker 2.1 atmega 328
the gps runs ok when mounted on uartsbee it opens in the binary consol of the ublox software ok
im using the fat16gps_CSVsensor logger example sketch
the gpsbee pinouts TX pin 2 RX pin 3
the baud rate in the ublox software runs at 9600
so I changed the pinouts and the baudrate in the sketch to match.
the code succesfully creates the csv file but no gps data seems to be written
heres the code im using any help in getting this to work would be most appreiciated
cheers ken
   // Ladyada's logger modified by Bill Greiman to use the Fat16 library
// this is a generic logger that does checksum testing so the data written should be always good
// Assumes a sirf III chipset logger attached to pin 0 and 1
uint8_t sensorCount = 3; //number of analog pins to log
#include <Fat16.h>
#include <Fat16util.h>
// macros to use PSTR
#define putstring(str) SerialPrint_P(PSTR(str))
#define putstring_nl(str) SerialPrintln_P(PSTR(str))
#define isdigit(x) ( x >= '0' && x <= '9')
//extern uint16_t _end;
SdCard card;
Fat16 f;
#define led1Pin 3              // LED1 connected to digital pin 3
#define led2Pin 2             // LED2 connected to digital pin 2
#define powerpin 2               // GPS power control
// set the  RX_BUFFER_SIZE to 32!
#define BUFFSIZE 73         // we buffer one NMEA sentense at a time, 83 bytes is longer than the max length
char buffer[BUFFSIZE];      // this is the double buffer
char buffer2[12];
uint8_t bufferidx = 0;
uint32_t tmp;
#define LOG_RMC  1      // essential location data
#define RMC_ON   "$PSRF103,4,0,1,1*21\r\n"  // the command we send to turn RMC on (1 hz rate)
#define RMC_OFF  "$PSRF103,4,0,0,1*20\r\n"  // the command we send to turn RMC off
#define LOG_GGA  0      // contains fix, hdop & vdop data
#define GGA_ON   "$PSRF103,0,0,1,1*25\r\n"   // the command we send to turn GGA on (1 hz rate)
#define GGA_OFF  "$PSRF103,0,0,0,1*24\r\n"   // the command we send to turn GGA off
#define LOG_GSA 0      // satelite data
#define GSA_ON   "$PSRF103,2,0,1,1*27\r\n"   // the command we send to turn GSA on (1 hz rate)
#define GSA_OFF  "$PSRF103,2,0,0,1*26\r\n"   // the command we send to turn GSA off
#define LOG_GSV  0      // detailed satellite data
#define GSV_ON   "$PSRF103,3,0,1,1*26\r\n"  // the command we send to turn GSV on (1 hz rate)
#define GSV_OFF  "$PSRF103,3,0,0,1*27\r\n"  // the command we send to turn GSV off
#define LOG_GLL 0      // Loran-compatibility data
// this isnt output by default
#define USE_WAAS   1     // useful in US, but slower fix
#define WAAS_ON    "$PSRF151,1*3F\r\n"       // the command for turning on WAAS
#define WAAS_OFF   "$PSRF151,0*3E\r\n"       // the command for turning off WAAS
#define LOG_RMC_FIXONLY 1  // log only when we get RMC's with fix?
uint8_t fix = 0; // current fix data
// read a Hex value and return the decimal equivalent
uint8_t parseHex(char c) {
    if (c < '0')
      return 0;
    if (c <= '9')
      return c - '0';
    if (c < 'A')
       return 0;
    if (c <= 'F')
       return (c - 'A')+10;
uint8_t i;
// blink out an error code
void error(uint8_t errno) {
   while(1) {
     for (i=0; i<errno; i++) {
       digitalWrite(led1Pin, HIGH);
       digitalWrite(led2Pin, HIGH);
       delay(100);
       digitalWrite(led1Pin, LOW);
       digitalWrite(led2Pin, LOW);
       delay(100);
     for (; i<10; i++) {
       delay(200);
void setup()                    // run once, when the sketch starts
  putstring_nl("GPSlogger");
  pinMode(led1Pin, OUTPUT);      // sets the digital pin as output
  pinMode(led2Pin, OUTPUT);      // sets the digital pin as output
  pinMode(powerpin, OUTPUT);
  digitalWrite(powerpin, LOW);
  if (!card.init()) {
    putstring_nl("Card init. failed!");
    error(1);
  if (!Fat16::init(&card)) {
    putstring_nl("No partition!");
    error(2);
  strcpy(buffer, "GPSLOG00.CSV");
  for (i = 0; i < 100; i++) {
    buffer[6] = '0' + i/10;
    buffer[7] = '0' + i%10;
    // create if does not exist, do not open existing, write
    if (f.open(buffer, O_CREAT | O_EXCL | O_WRITE)) break;
  if(!f.isOpen()) {
    putstring("couldnt create "); Serial.println(buffer);
    error(3);
  putstring("writing to "); Serial.println(buffer);
  putstring_nl("ready!");
  // write header
  if (sensorCount > 6) sensorCount = 6;
  strncpy_P(buffer, PSTR("time,lat,long,speed,date,sens0,sens1,sens2,sens3,sens4,sens5"), 24 + 6*sensorCount);
  // clear write error
  f.writeError = false;
  f.println(buffer);
  if (f.writeError || !f.sync()) {
    putstring_nl("can't write header!");
    error(4);
   putstring("\r\n");
#if USE_WAAS == 1
   putstring(WAAS_ON); // turn on WAAS
#else
  putstring(WAAS_OFF); // turn on WAAS
#endif
#if LOG_RMC == 1
  putstring(RMC_ON); // turn on RMC
#else
  putstring(RMC_OFF); // turn off RMC
#endif
#if LOG_GSV == 1
  putstring(GSV_ON); // turn on GSV
#else
  putstring(GSV_OFF); // turn off GSV
#endif
#if LOG_GSA == 1
  putstring(GSA_ON); // turn on GSA
#else
  putstring(GSA_OFF); // turn off GSA
#endif
#if LOG_GGA == 1
 putstring(GGA_ON); // turn on GGA
#else
 putstring(GGA_OFF); // turn off GGA
#endif
void loop()                     // run over and over again
  //Serial.println(Serial.available(), DEC);
  char c;
  uint8_t sum;
  // read one 'line'
  if (Serial.available()) {
    c = Serial.read();
    //Serial.print(c, BYTE);
    if (bufferidx == 0) {
      while (c != '
the code snippet exceed max will copy paste and post the remainder next)
       c = Serial.read(); // wait till we get a $
   buffer[bufferidx] = c;
   if (c == ‘\n’) {
     //putstring_nl(“EOL”);
     //Serial.print(buffer);
     buffer[bufferidx+1] = 0; // terminate it
hers the remaining part of code
     if (buffer[bufferidx-4] != '*') {
        // no checksum?
        Serial.print('*', BYTE);
        bufferidx = 0;
        return;
      // get checksum
      sum = parseHex(buffer[bufferidx-3]) * 16;
      sum += parseHex(buffer[bufferidx-2]);
      // check checksum
      for (i=1; i < (bufferidx-4); i++) {
        sum ^= buffer[i];
      if (sum != 0) {
        //putstring_nl("Cxsum mismatch");
        Serial.print('~', BYTE);
        bufferidx = 0;
        return;
      // got good data!
      if (strstr(buffer, "GPRMC")) {
        // find out if we got a fix
        char* p = buffer;
        p = strchr(p, ',')+1;
        p = strchr(p, ',')+1;       // skip to 3rd item
        if (p[0] == 'V') {
          fix = 0;
          fix = 1;
        // not GPRMC
        bufferidx = 0;
        return;
#if LOG_RMC_FIXONLY
      if (!fix) {
          Serial.print('_', BYTE);
          bufferidx = 0;
          return;
#endif
      // rad. lets print it!
      // time to clean up the string
      // find time
      char* p = buffer;
      buffer[0] = p[0];
      buffer[1] = p[1];
      buffer[2] = ':';
      buffer[3] = p[2];
      buffer[4] = p[3];
      buffer[5] = ':';
      buffer[6] = p[4];
      buffer[7] = p[5];
      // we ignore milliseconds
      buffer[8] = ',';
      p = strchr(buffer+8, ',')+1;
      // skip past 'active' flag
      // find lat
      buffer[9] = '+';
      buffer[10] = p[0];
      buffer[11] = p[1];
      buffer[12] = ' ';
      strncpy(buffer+13, p+2, 7);
      buffer[20] = ',';
      p = strchr(buffer+21, ',')+1;
      if (p[0] == 'S')
        buffer[9] = '-';
      // find long
      buffer[21] = '+';
      buffer[22] = p[0];
      buffer[23] = p[1];
      buffer[24] = p[2];
      buffer[25] = ' ';
      strncpy(buffer+26, p+3, 7);
      buffer[33] = ',';
      p = strchr(buffer+34, ',')+1;
      if (p[0] == 'W')
        buffer[21] = '-';
      // find speed
      tmp = 0;
      if (p[0] != ',') {
        // ok there is some sort of speed
        while (p[0] != '.' && p[0] != ',') {
          tmp *= 10;
          tmp += p[0] - '0';
          p++;
        tmp *= 10;
        if (isdigit(p[1]))
          tmp += p[1] - '0'; // tenths
        tmp *= 10;
        if (isdigit(p[2]))
        tmp += p[2] - '0'; // hundredths
        // tmp is knots * 100
        // convert to mph (1.15 mph = 1 knot)
        tmp *= 115;
        // -OR- convert km/h
        // tmp *= 185
      tmp /= 100;
      buffer[34] = (tmp / 10000) + '0';
      tmp %= 10000;
      buffer[35] = (tmp / 1000) + '0';
      tmp %= 1000;
      buffer[36] = (tmp / 100) + '0';
      tmp %= 100;
      buffer[37] = '.';
      buffer[38] = (tmp / 10) + '0';
      tmp %= 10;
      buffer[39] = tmp + '0';
      buffer[40] = ',';
      // skip past bearing
      //mod for bug when speed,bearing are missing (bill greiman)
      uint8_t date[6];
      for (uint8_t id = 0; id < 6; id++) date[id] = p[id];
      // get date into 2001-01-31 style
      buffer[41] = '2';
      buffer[42] = '0';
      buffer[43] = date[4];
      buffer[44] = date[5];
      buffer[45] = '-';
      buffer[46] = date[2];
      buffer[47] = date[3];
      buffer[48] = '-';
      buffer[49] = date[0];
      buffer[50] = date[1];
      buffer[51] = 0;
      if(f.write((uint8_t*) buffer, 51) != 51) {
         putstring_nl("can't write fix!");
	 return;
      // add sensor data
      for (uint8_t ia = 0; ia < sensorCount; ia++) {
        Serial.print(',');
        f.print(',');
        uint16_t data = analogRead(ia);
        Serial.print(data);
        f.print(data);
      f.println();
         putstring_nl("can't write data!");
	 return;
      bufferidx = 0;
      return;
    bufferidx++;
    if (bufferidx == BUFFSIZE-1) {
       Serial.print('!', BYTE);
       bufferidx = 0;
cheers ken
You seem to be reading from Serial to get the GPS data, and writing to Serial for debugging. That doesn't seem right, to me.
hi paul thanks for the reply
can you suggest a solution
Use a software serial port for the GPS, unless it is hardwired to the hardware pins. If that is the case, an LCD is about your only other debugging option.
