gradually filling a led strip like tetris ?
hello i made this working with 1 led only. how should i modify the code in order to have more than 1 led moving? lets say 4 for example. same sequence, but 4 leds each time instead of 1.
check attached link for video example.
arduino gradual fill test video
#define PIN 6
#define NUM_PIXELS 30
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_PIXELS, PIN, NEO_GRB + NEO_KHZ800);
  strip.setBrightness(30);
  strip.begin();
  strip.show();
  int i, j;
 for (uint16_t i = 0; i < strip.numPixels() ; i++) {
   int r = (255);
   int g = (50);
   int b = (0);
    for (uint16_t j = 0; j < strip.numPixels() - i; j++) {
      strip.setPixelColor(j - 1, strip.Color(0, 0, 0));
      strip.setPixelColor(j, strip.Color(r, g , b));
      strip.show();
      delay(5);
If you could only make “j” bigger in that line.. even better if you incremented it bigger.
i tried strip.setPixelColor(j++, strip.Color(r, g , b));
and other stuff but the result is not the one needed.
mitsakos:
You need to call that function n times to make n pixels light up.
   int r = (255);
   int g = (50);
   int b = (0);
(The) (parentheses) (add) (no) (value).
      strip.show();
      delay(5);
Here, you are turning off one pixel before turning on another pixel. To have more than one pixel on, clearly the - 1 needs to be - 2 or - 3 or - 4… You need to make sure that j - n is never less than 0, though.
PaulS:
   int r = (255);
int g = (50);
  int b = (0);
      strip.show();
      delay(5);
Here, you are turning off one pixel before turning on another pixel. To have more than one pixel on, clearly the - 1 needs to be - 2 or - 3 or - 4... You need to make sure that j - n is never less than 0, though.
this lights up only the first 4 leds in the sequence, the rest still come 1 by 1. i tried the j -4
Show the code. How are you making sure that j - 4 is a valid value to use in the call to setPixelColor()?
#define PIN 6
int delayval = 300;
  strip.begin();
  strip.show();
  int i, j;
  delay(delayval);
 for (uint16_t i = 0; i < strip.numPixels() ; i++) { // iterate over every LED of the strip
   int r = (255);
   int g = (50);
   int b = (0);
      strip.setPixelColor(j - 4, strip.Color(0, 0, 0));
      strip.setPixelColor(j , strip.Color(r, g , b));
      strip.show();
      delay(5);
i am not sure about your latest response, i am amateur at these stuff.
    for (uint16_t j = 0; ....
So when j starts at zero, what pixel does j-4 refer to?
Don't attempt to set non-existent pixels. This can crash your Arduino because you are writing to memory locations used for other purposes. There is no automatic protection against this.
MorganS:
i am not sure i understand your question aswell. any guidance/help would be awesome. when i set the
strip.setPixelColor(j - 1/2/3/4 the 1st row of leds that light up correspond to that value. if i use j - 3, 3 led fill the row and then 1 by 1
j -4 example
should be
      if(j >= 4)
This will set the 0 pixel on, then set the 1 pixel on, then set the 2 pixel on, then set the 3 pixel on, then set the 4 pixel on AND the 0 pixel off, then set the 5 pixel on AND the 1 pixel off…
MorganS:
There is !! he is using adafruit_neopixel !!
To let the thing rotate at the end you can make use of the % modulo
      strip.setPixelColor(j , strip.Color(0, 0, 0));
      strip.setPixelColor((j + 4) % strip.numPixels() , strip.Color(r, g , b));
