Graph I/O
I would like to graph multiple I/O on my Arduino project.
What i want to achieve is a line graph that will show:
Water Level (%)
vs
Pump Status (on/off)
I currently have this data output to the serial monitor. I would like the graph to update in real time but also show a historical plot. I have found the Serial Plotter but it does not do what i want to achieve only showing my water level and not when the pump on/off.
I was wondering if anyone had some suggestions on possible ways i could go about achieving this.
Would i need to create a GUI? or interface with some software? or is there ready made solutions for this?
Many of us use the PLXDAQ macro to interface Arduino directly with Excel, through the serial port.
Works very well, and you can add a time stamp to the incoming data, which is extremely useful.
The Arduino IDE does have the Tools > Serial Plotter feature. You can't do Water Level (%) vs Pump Status (on/off), but I don't think that makes sense anyway. What you can do is Water Level (%) and Pump Status (on/off) vs Time.
Save the data to an SD card on the Arduino and then put the card in the PC when you have finished your logging session.
You can make your own GUI using, Processing.
It has an edit screen like Arduino IDE and many, many diffrerent examples.
Tom... :slight_smile:
pert:
Thats what i meant. I havnt been able to get it to work though while the pump('s) change state 0->1 1->0 the line on the graph stays constant.
jremington:
This looks ideal
TomGeorge:
Download Processing / Processing.org
thanks i think PLX as suggested above will do what i need but i will take a look at this out of curiosity
mtom1991:
It sounds like you're going with another solution but if you do decide you want to try to get Serial Plotter working, post your code and we should be able to help you.
Serial Plotter is far from ideal but it is convenient since it comes with the Arduino IDE.
Can you post your code please between code tags?
This should help with Serial Plot
https://www.google.com/search?q=arduino+plotter+multiple+values&rlz=1C1CHBF_en-GBAU821AU821&oq=arduino+plott+multiple&aqs=chrome.1.69i57j0l4.9549j0j8&sourceid=chrome&ie=UTF-8
