graph plotting with arduino
hello everyone! does anyone know how to plot a graph with Arduino output? i have read tutorials about plotting using processing and the analog output of the Arduino.
I want to plot a polar graph using the magnitude of an ultrasonic sensor against the angle of a servo.
    #include <NewPing.h>
    #define TRIGGER_PIN  12 // Arduino pin tied to trigger pin on the ultrasonic sensor.
    #define ECHO_PIN     11  // Arduino pin tied to echo pin on the ultrasonic sensor.
    #define MAX_DISTANCE 200 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
    String readString;
    #include <Servo.h>
    Servo myservo;  // create servo object to control a servo
    NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
      Serial.begin(9600); // Open serial monitor at 115200 baud to see ping results.
      myservo.writeMicroseconds(1500); //set initial servo position if desired
      myservo.attach(7);  //the pin for the servo control
      Serial.println("Input angle in Serial");
      while (Serial.available()) {
        char c = Serial.read();  //gets one byte from serial buffer
        readString += c; //makes the string readString
        delay(2);  //slow looping to allow buffer to fill with next character
      if (readString.length() >0) {
        Serial.println(readString);  //so you can see the captured string
        int n = readString.toInt();  //convert readString into a number
        // auto select appropriate value, copied from someone elses code.
        if(n >= 500)
          Serial.print("writing Microseconds: ");
          Serial.println(n);
          myservo.writeMicroseconds(n);
          Serial.print("writing Angle: ");
          Serial.println(n);
          myservo.write(n);
        readString=""; //empty for next input
      delay(500);                      // Wait 50ms between pings (about 20 pings/sec). 29ms should be the shortest delay between pings.
      unsigned int uS = sonar.ping(); // Send ping, get ping time in microseconds (uS).
      Serial.print("Ping: ");
      Serial.print(uS / US_ROUNDTRIP_CM); // Convert ping time to distance and print result (0 = outside set distance range, no ping echo)
      Serial.println("cm");
      if((uS / US_ROUNDTRIP_CM)<=5 && (uS / US_ROUNDTRIP_CM)!=0  )
      Serial.print("Too Close");
the outputs are
magnitude = (uS / US_ROUNDTRIP_CM)!=0 )
Angle = Servo Angle
any suggestions will be great =) thanks!
I must be starting to sound like some droning evangelist on this but I have to say exporting the data to Excel would have to be the way to go first. This can be done by:
Recording the data as a CSV file on SD for subsequent use by Excel
Sending the data to a terminal programme for subsequent transfer to Excel
Using the PLX-DAQ macro whereby Excel becomes the terminal and receives the data directly.
I recognise that proper polar charts are not in Excel 2003's repertoire but I understand it can be persuaded to deliver. Later versions of Excel may be more able to do them solo, but probably not!
Here is some background on PLX
http://homepages.ihug.com.au/~npyner/Arduino/GUIDE_2PLX.pdf
hi! that sounds like a great idea! but does it support real time plotting?
cheers!
DMond:
I can't give you the code (because I am not familiar enough with Processing), but I think I can point you in the right direction, if you are able to follow along.
First, take a look at this page:
This is the basics of plotting a circle, using what is call the "parametric equation of a circle" - which is:
x = cx + r * cos(ang)
y = cy + r * sin(ang)
...where:
x, y = end point coordinates on the circle
cx, cy = centerpoint coordinates of the circle
r = radius of the circle
ang = angle (in radians)
So - first convert your angle from the servo (0-359?) into radians via:
ang = (PI * deg) / 180
...where:
ang = angle in radians
PI = 3.14159265359
deg = angle in degrees
Then plug that into the above "parametric equation of a circle", along with your "r" - which will be the magnitude value from your ping response (you may need to do some scaling depending on what you get out).
So - say you have a window/screen for graphics opened in processing (however you do that), and that window is sized 640 x 480. So you read the angle of the servo in degrees (deg) and magnitude of the sensor (dist) - to plot it:
ang = (PI * deg) / 180; // convert angle in degrees to radians
x = 320 + dist * cos(ang); // find x-coordinate centered on screen
y = 240 + dist * sin(ang); // find y-coordinate centered on screen
drawline 320, 240 to x, y; // draw a line from the center of the screen to the length given for the "ping"
Ok - note that the above is all basically "pseudocode" and not real processing code - but it should be enough to get you going - hopefully.
Good luck!
:slight_smile:
DMond:
Indeed it does. Check the background notes I linked, that is what it is all about. And its a freebie........
I first thought there was some live graphing magic in PLX-DAQ and it has taken me a couple of years to realise that it is merely a terminal interface for Excel, but that is all it needs to be. All the magic is actually in Excel and any Excel graph may be plotted in real time.
Search for my post on PLX-DAQ.
Just a few simple commands.
It's a very simple way to go if you are already using windows, with excel.
hi!
first i have to say, that i havnt tried plotting a graph for myself. but i read and saw a code wich is plotting a sensor-value in a x-y-system. it looks not very difficult.
here you can find a example, plotting random numbers in a x-y-system.
http://www.learningprocessing.com/examples/chapter-13/example-random-graph/
perhaps this could help you for your first steps?
