I need some suggestion on selecting display and Arduino based development board for my application. I am planning to make product which uses graphical display with key
Key operation:
Increment
Decrements
Menu selection
STOP operation
Control output:
Relay
Stepper motor 2 nos
Heater coils
Sensor:
temperature sensor
Limit sensors
Display :
Should be display all parameter
kindly let me know do above thing which development board hold good.
Just a suggestion: Fix your subject line in your first post.
It's serious. If you appear not to be able to type, people may be less disposed to help you - since typing accurately is an absolute prerequisite for computer coding.
AJITnayak:
the generic way to start is for you to make a few lists. #1) list every digital input #2) list every digital output #3) list every analog input #4) list every analog output
then, get a data sheet for every I/O point and make sure you have all the correct power and voltages, etc.
in some cases, you need only 1 pin for many sensors, for example the DS18B20 temperature sensor.
get this started and as you get an exact pin count and voltages, the correct microcontroller almost picks itself.
