Graphing Code from TUtorial Not Working (IDE + Processing)
I'm on Arch Linux, using Arduino 1.6.5 and Processing 3.0b6
Using code from https://www.arduino.cc/en/Tutorial/Graph
I'm trying to graph the input from my Arduino DUE, with the following code:
Tools -> Boards : Arduino DUE (Programming Port)
Tools -> Port -> /dev/ttyACM0
Open Arduino IDE, paste this:
  // initialize the serial communication:
  // send the value of analog input 0:
  Serial.println(analogRead(A0));
  // wait a bit for the analog-to-digital converter
  // to stabilize after the last reading:
  delay(2);
Chmod A+RW /dev/ttyAMC0
Open Processing, paste this:
import processing.serial.*;
Serial myPort;        // The serial port
int xPos = 1;         // horizontal position of the graph
void setup () {
// set the window size:
size(400, 300);
// List all the available serial ports
println(Serial.list());
// I know that the first port in the serial list on my mac
// is always my  Arduino, so I open Serial.list()[0].
// Open whatever port is the one you're using.
myPort = new Serial(this, Serial.list()[0], 9600);
// don't generate a serialEvent() unless you get a newline character:
myPort.bufferUntil('\n');
// set inital background:
background(0);
void draw () {
// everything happens in the serialEvent()
void serialEvent (Serial myPort) {
// get the ASCII string:
String inString = myPort.readStringUntil('\n');
if (inString != null) {
// trim off any whitespace:
inString = trim(inString);
// convert to an int and map to the screen height:
float inByte = float(inString);
inByte = map(inByte, 0, 1023, 0, height);
// draw the line:
stroke(127,34,255);
line(xPos, height, xPos, height - inByte);
// at the edge of the screen, go back to the beginning:
if (xPos >= width) {
xPos = 0;
background(0);
else {
// increment the horizontal position:
xPos++;
Hit Run.
Problem: Console output
/dev/ttyACM0 /dev/ttyS0 /dev/ttyS1 /dev/ttyS2 /dev/ttyS3
map(NaN, 0, 1023, 0, 300) called, which returns NaN (not a number)
And a window with black background and nothing else appears.
Please help, the graph code won't work on Windows either.
Please check if my step has anything wrong with it.
Thanks.
Please note that I don't give input to A0 (A0 not wired), and the serial monitor still gives me a stream of random number 0-1023.
Most likely because the Arduino is not on the port that Processing thinks it is.
Print the list of serial ports. Make sure that the Arduino IS connected to the one that you tell Processing it is connected to.
The port is the same, /dev/ttyACM0, a print of Serial.list()[0] yields that.
Also a print(inByte) in Processing output a stream of random float as expected.
But why map still says the first parameter (value) is not a float !! ??
I rewrote the map function and it still not graph for me...
float hahaha(float value, float istart, float istop, float ostart, float ostop) {
  float res = ostart + (ostop - ostart) * ((value - istart) / (istop - istart));
  print(res,'\n');
    return res;
inByte = hahaha(inByte, 0, 1023, 0, height);
Console output:
68.035194
153.66568
175.95308
87.68328
67.741936
173.02052
160.70383
76.24633
73.02053
173.02052
145.16129
70.087975
84.45748
185.04399
140.76247
63.04985
99.70675
188.56305
123.75366
65.68915
122.28739
185.04399
103.81232
65.68915
125.21994
178.00586
89.14957
68.914955
152.19942
178.59238
78.00586
73.31378
172.43402
160.11731
77.1261
81.52493
183.28445
141.93549
68.621704
83.28446
190.90909
125.51319
66.56892
98.53373
192.37537
106.158356
67.44868
123.75366
191.20235
106.744865
67.741936
147.80058
180.05865
92.37537
69.20821
168.32845
165.68915
83.28446
78.88563
164.80939
139.00293
76.83284
90.909096
177.41934
139.00293
73.02053
100.58651
180.35191
125.51319
75.95308
121.40762
176.83284
102.93255
75.07331
122.8739
169.79472
94.134895
79.7654
145.16129
168.6217
84.45748
82.69795
162.7566
155.42522
84.45748
88.8563
171.261
138.41643
78.00586
91.20235
175.36656
124.63343
76.53959
101.17302
176.24632
109.38417
78.29912
121.11437
174.78006
105.571846
79.47214
139.58945
165.3959
95.60117
81.231674
155.71848
154.2522
88.56305
84.16422
156.01172
141.93549
83.57771
92.961876
167.74194
139.00293
80.35191
100.58651
171.55424
128.1525
82.40469
115.83578
170.08798
108.5044
81.231674
117.888565
165.9824
99.41349
84.16422
137.24341
165.3959
92.082115
87.39003
153.66568
153.07918
91.78886
92.082115
163.34311
140.17595
85.04399
92.961876
167.74194
127.85924
82.69795
101.75953
169.79472
111.73021
83.57771
117.595314
171.55424
112.02346
83.57771
134.89735
164.51613
100.29326
84.75073
151.6129
153.66568
90.61584
86.21701
153.66568
140.76247
85.04399
92.668625
167.15543
144.28152
80.93842
99.41349
171.261
127.56599
81.818184
112.60997
172.43402
112.60997
80.058655
113.48974
168.91496
102.6393
84.16422
134.31085
168.6217
92.37537
85.92375
151.90616
158.06451
92.37537
89.14957
163.34311
145.16129
85.92375
91.20235
169.2082
129.03226
82.40469
99.70675
170.96774
118.76833
82.11144
112.02346
173.60704
116.71554
81.52493
129.61877
168.03519
101.75953
82.9912
147.50734
158.06451
92.668625
85.04399
148.09384
148.9736
87.97654
90.322586
163.04987
148.9736
82.40469
96.77419
169.2082
132.55132
83.87097
106.744865
171.8475
121.11437
81.52493
107.03812
170.08798
108.79766
83.28446
125.80645
169.79472
97.3607
85.6305
143.40176
161.29033
97.94721
87.39003
156.59824
150.43988
91.20235
89.14957
165.10265
135.19061
85.33724
96.480934
166.27567
124.63343
84.16422
105.27859
170.67448
127.27273
82.9912
121.11437
168.32845
108.21115
84.45748
138.41643
160.70383
99.12024
85.6305
138.70969
153.07918
94.134895
90.02933
154.8387
150.43988
86.51026
95.60117
164.51613
137.24341
87.97654
101.46628
167.74194
127.27273
84.75073
102.93255
169.50146
110.55719
85.04399
119.648094
169.79472
101.46628
86.51026
136.95015
163.92963
102.6393
87.09677
151.0264
152.19942
93.841644
88.26979
162.17009
139.00293
87.97654
94.428154
162.7566
130.20528
86.51026
101.75953
167.74194
131.08504
84.16422
114.66276
167.44868
113.78299
86.21701
131.3783
161.29033
103.81232
87.39003
132.25806
154.54546
98.24046
90.61584
148.09384
153.95894
91.495605
94.721405
158.35776
143.695
93.255135
100.29326
162.17009
128.739
89.73608
102.05279
165.3959
117.0088
88.56305
113.78299
165.68915
108.21115
90.322586
130.20528
161.87685
107.03812
89.14957
144.57478
154.2522
98.82698
89.44282
156.01172
143.695
92.37537
92.961876
157.18474
131.08504
88.26979
100.29326
165.10265
131.96481
84.45748
110.26393
167.15543
120.52786
85.6305
125.80645
163.34311
104.98534
85.33724
127.27273
157.77126
98.53373
87.68328
144.28152
158.94427
91.20235
90.909096
157.478
145.45454
91.495605
96.480934
164.51613
132.55132
86.51026
97.3607
168.32845
122.8739
85.33724
108.21115
169.2082
107.331375
85.6305
125.51319
167.74194
107.624626
85.6305
141.34897
158.94427
98.53373
86.51026
155.42522
148.9736
91.78886
89.73608
156.30498
135.19061
86.21701
97.067444
166.56892
135.77711
82.69795
104.39883
169.50146
125.51319
84.45748
120.52786
167.15543
106.744865
83.87097
122.28739
162.17009
99.41349
86.21701
140.46921
162.7566
92.668625
88.8563
155.71848
149.85338
92.37537
93.841644
164.51613
136.65689
85.6305
94.721405
169.79472
126.39296
83.28446
102.93255
170.38123
109.38417
83.87097
120.82111
170.96774
109.97068
83.87097
137.53667
163.34311
100.87977
85.04399
152.78592
151.31964
91.495605
87.39003
153.66568
140.17595
87.09677
94.134895
165.68915
142.52199
82.9912
100.87977
169.50146
126.68622
84.16422
115.54252
169.2082
110.85044
82.40469
116.71554
165.9824
103.22581
85.33724
135.77711
165.3959
93.255135
87.09677
151.90616
154.8387
93.548386
90.909096
162.7566
143.1085
87.39003
92.082115
168.32845
128.1525
83.57771
100.58651
169.79472
114.95601
83.28446
114.66276
171.8475
118.475075
83.28446
131.3783
165.3959
102.05279
84.16422
148.09384
155.71848
93.841644
85.6305
148.3871
146.62756
89.44282
92.082115
162.46335
143.695
83.28446
98.82698
It seems that drawing from the SerialEvent just does not work.
Try this version for the receive, NaN s are shown as 'missing' bars
float fValue;
boolean newVal = false;
void setup () {
  size(400, 300);
  myPort = new Serial(this, Serial.list()[0], 115200);
  background(0);
  stroke(127, 34, 255);
void draw () {
  if (newVal) {
    line(xPos, height, xPos, height - fValue);
    if (++xPos >= width) {
      xPos = 0;
      background(0);
    newVal = false;
    fValue = float(inString);
    fValue = map(fValue, 0, 1023, 0, height);
    newVal = true;
Here, I tried your code, and yet the graph doesn't show
(Image attached)
The graph box is shown, but nothing on there really.
I don't know why it's so hard... your code still sometimes generate map NaN error, don't know the reason.
It is your data that produces the NaN, everytime something comes in that is, as the name implies, 'Not a Number'.
Or maybe it's Processing's functions that are so bad...
Change to a random function (to leave out NaN):
inByte = random(0,1023);
print(inByte,"\n");
Still a black window with no graph.
Were you able to graph with your code ?
Unlikely!
Patently STUPID name for a variable of type float. Do you have some PROOF that inString contains a float representation?
The map function expects a integer value as input. Why would you be passing it a float?
PaulS:
Sorry PaulS, this is Processing...
Description 	Re-maps a number from one range to another.
In the first example above, the number 25 is converted from a value in the range of 0 to 100 into a value that ranges from the left edge of the window (0) to the right edge (width).
As shown in the second example, numbers outside of the range are not clamped to the minimum and maximum parameters values, because out-of-range values are often intentional and useful.
Syntax
map(value, start1, stop1, start2, stop2)
Parameters
value 	float: the incoming value to be converted
start1 	float: lower bound of the value's current range
stop1 	float: upper bound of the value's current range
start2 	float: lower bound of the value's target range
stop2 	float: upper bound of the value's target range
I totally agree to the absolutly stupid name.
I just made the P-sketch work here and had it fed by an Arduino application that generated some values and text,
I was getting the NaNs on text.
Nice one Whandall - I banged my head against the wall with this, downloaded 'latest' code from Tom Igoe's GitHib (MakingThingsTalk2/SerialStringReaderGrapher.pde at main · tigoe/MakingThingsTalk2 · GitHub) but still no joy.
Then - used your code, sucess, and enjoyed playing with my FSR!!
Regarding the NaN problem: map(NaN, 0, 1023, 0, 300) called, which returns NaN (not a number)
  • I still get that with Whandall's code, but the program still works, and graphs nicely...
If we NEED a fix, I found that adding a println() fixed the NaN issue. You can print anything, but following the code from the book, I used the original
println(sensorValue);
I also changed the code around a bit - changed back variable names, and kept the drawGraph as a separate function:
   Serial String Reader
   Context: Processing
   Reads in a string of characters until it gets a linefeed (ASCII 10).
   Then converts the string into a number.
   Modified by Whandall
Serial myPort;              // the serial port
float sensorValue = 0;      // the value from the sensor
float prevSensorValue = 0;  // previous value from the sensor
float lastXPos = 0;         // previous horizontal position
  size(400, 300);
  myPort = new Serial(this, Serial.list()[2], 115200);
  background(0);
void draw () {
  drawGraph();
    sensorValue = float(inString);
    sensorValue = map(sensorValue, 0, 1023, 0, height);
    newVal = true;
void drawGraph()  {
    if (newVal) {
    line(xPos, height, xPos, height - sensorValue);
      xPos = 0;
      background(0);
    newVal = false;
