hello guys some one please can help me with this GaravityTDS librery have can i add function read from ADS1115 or pin, with old function there i write all library.
I try to use
int16_t adc0;
adc0 = ads.readADC_SingleEnded(0);
and sent the result to pin librery
TDS library.
#include <EEPROM.h>
#include <GravityTDS.h>
#include <Wire.h>
#define EEPROM_write(address, p) {int i = 0; byte *pp = (byte*)&(p);for(; i < sizeof(p); i++) EEPROM.write(address+i, pp[i]);}
#define EEPROM_read(address, p) {int i = 0; byte *pp = (byte*)&(p);for(; i < sizeof(p); i++) pp[i]=EEPROM.read(address+i);}
GravityTDS::GravityTDS()
this->pin = 0;
this->temperature = 25.0;
this->aref = 5.0;
this->adcRange = 32767.0;
this->kValueAddress = 8;
this->kValue = 1.0;
GravityTDS::~GravityTDS()
void GravityTDS::setPin(int pin)
this->pin = pin;
void GravityTDS::setTemperature(float temp)
this->temperature = temp;
void GravityTDS::setAref(float value)
this->aref = value;
void GravityTDS::setAdcRange(float range)
this->adcRange = range;
void GravityTDS::setKvalueAddress(int address)
this->kValueAddress = address;
void GravityTDS::begin()
pinMode(this->pin,INPUT);
readKValues();
float GravityTDS::getKvalue()
return this->kValue;
void GravityTDS::update()
this->analogValue = analogRead(this->pin);
this->voltage = this->analogValue/this->adcRange*this->aref;
this->ecValue=(133.42*this->voltage*this->voltage*this->voltage - 255.86*this->voltage*this->voltage + 857.39*this->voltage)*this->kValue;
this->ecValue25 = this->ecValue / (1.0+0.02*(this->temperature-25.0)); //temperature compensation
this->tdsValue = ecValue25 * TdsFactor;
Serial.print(kValue);
Serial.println(" kValue");
if(cmdSerialDataAvailable() > 0)
ecCalibration(cmdParse()); // if received serial cmd from the serial monitor, enter into the calibration mode
float GravityTDS::getTdsValue()
return tdsValue;
float GravityTDS::getEcValue()
return ecValue25;
void GravityTDS::readKValues()
EEPROM_read(this->kValueAddress, this->kValue);
if(EEPROM.read(this->kValueAddress)==0xFF && EEPROM.read(this->kValueAddress+1)==0xFF && EEPROM.read(this->kValueAddress+2)==0xFF && EEPROM.read(this->kValueAddress+3)==0xFF)
this->kValue = 1.0; // default value: K = 1.0
EEPROM_write(this->kValueAddress, this->kValue);
boolean GravityTDS::cmdSerialDataAvailable()
char cmdReceivedChar;
static unsigned long cmdReceivedTimeOut = millis();
while (Serial.available()>0)
if (millis() - cmdReceivedTimeOut > 500U)
cmdReceivedBufferIndex = 0;
memset(cmdReceivedBuffer,0,(ReceivedBufferLength+1));
cmdReceivedChar = Serial.read();
if (cmdReceivedChar == '\n' || cmdReceivedBufferIndex==ReceivedBufferLength){
strupr(cmdReceivedBuffer);
return true;
}else{
cmdReceivedBuffer[cmdReceivedBufferIndex] = cmdReceivedChar;
cmdReceivedBufferIndex++;
return false;
byte GravityTDS::cmdParse()
byte modeIndex = 0;
if(strstr(cmdReceivedBuffer, "ENTER") != NULL)
modeIndex = 1;
else if(strstr(cmdReceivedBuffer, "EXIT") != NULL)
modeIndex = 3;
else if(strstr(cmdReceivedBuffer, "CAL:") != NULL)
modeIndex = 2;
return modeIndex;
void GravityTDS::ecCalibration(byte mode)
char *cmdReceivedBufferPtr;
static boolean ecCalibrationFinish = 0;
static boolean enterCalibrationFlag = 0;
float KValueTemp,rawECsolution;
switch(mode)
case 0:
if(enterCalibrationFlag)
Serial.println(F("Command Error"));
case 1:
enterCalibrationFlag = 1;
Serial.println(F(">>>Enter Calibration Mode<<<"));
Serial.println(F(">>>Please put the probe into the standard buffer solution<<<"));
case 2:
cmdReceivedBufferPtr=strstr(cmdReceivedBuffer, "CAL:");
cmdReceivedBufferPtr+=strlen("CAL:");
rawECsolution = strtod(cmdReceivedBufferPtr,NULL)/(float)(TdsFactor);
rawECsolution = rawECsolution*(1.0+0.02*(temperature-25.0));
// Serial.print("rawECsolution:");
// Serial.print(rawECsolution);
// Serial.print(" ecvalue:");
// Serial.println(ecValue);
KValueTemp = rawECsolution/(133.42*voltage*voltage*voltage - 255.86*voltage*voltage + 857.39*voltage); //calibrate in the buffer solution, such as 707ppm(1413us/cm)@25^c
if((rawECsolution>0) && (rawECsolution<2000) && (KValueTemp>0.25) && (KValueTemp<4.0))
Serial.print(F(">>>Confrim Successful,K:"));
Serial.print(KValueTemp);
Serial.println(F(", Send EXIT to Save and Exit<<<"));
kValue = KValueTemp;
ecCalibrationFinish = 1;
else{
Serial.println(F(">>>Confirm Failed,Try Again<<<"));
case 3:
if(ecCalibrationFinish)
EEPROM_write(kValueAddress, kValue);
EEPROM.commit();
Serial.print(F(">>>Calibration Successful,K Value Saved"));
else Serial.print(F(">>>Calibration Failed"));
Serial.println(F(",Exit Calibration Mode<<<"));
and gravity.h
#ifndef GRAVITY_TDS_H
#define GRAVITY_TDS_H
#include "Arduino.h"
#define ReceivedBufferLength 15
#define TdsFactor 0.5 // tds = ec / 2
class GravityTDS
public:
GravityTDS();
~GravityTDS();
void begin(); //initialization
void update(); //read and calculate
void setPin(int pin);
void setTemperature(float temp); //set the temperature and execute temperature compensation
void setAref(float value); //reference voltage on ADC, default 5.0V on Arduino UNO
void setAdcRange(float range); //1024 for 10bit ADC;4096 for 12bit ADC
void setKvalueAddress(int address); //set the EEPROM address to store the k value,default address:0x08
float getKvalue();
float getTdsValue();
float getEcValue();
private:
int pin;
float aref; // default 5.0V on Arduino UNO
float adcRange;
float temperature;
int kValueAddress; //the address of the K value stored in the EEPROM
char cmdReceivedBuffer[ReceivedBufferLength+1]; // store the serial cmd from the serial monitor
byte cmdReceivedBufferIndex;
float kValue; // k value of the probe,you can calibrate in buffer solution ,such as 706.5ppm(1413us/cm)@25^C
float analogValue;
float voltage;
float ecValue; //before temperature compensation
float ecValue25; //after temperature compensation
float tdsValue;
void readKValues();
boolean cmdSerialDataAvailable();
byte cmdParse();
void ecCalibration(byte mode);
#endif
