Great distance between a Yun and a sensor
I’ve an ultrasonic device (HC-SR04) attached to a Yun which is working fine. However, if I add approx. 20 meters of shielded cable between the HC-SR04 and the Yun, the ultrasonic stops working.
I suspect the TTL waveforms get distorted so the question is, is it safe to add a 4.7K pull-up resistor at the trigger input of the HC-SR04 and another one at the echo pin input of the Yun?
TIA
Yes it is safe.
How effective it will be in solving your problem is altogether an other matter.
