Here is performance of an old, 2004, 16 MB FAT12 card. I was using this old card to test the SdFat FAT12 option.
Here is the bench example results on an Uno:
Type any character to start
Free RAM: 598
Type is FAT12
Card size: 0.01 GB (GB = 1E9 bytes)Manufacturer ID: 0X3
OEM ID: SD
Product: SD016
Version: 5.5
Serial number: 0X4CB84C00
Manufacturing date: 2/2004File size 5 MB
Buffer size 512 bytes
Starting write test, please wait.write speed and latency
speed,max,min,avg
KB/Sec,usec,usec,usec
416.67,2244,824,1222
416.54,3724,1180,1223
416.71,3476,1180,1222
416.64,3472,1180,1223
416.64,3432,1180,1222
416.67,3480,1180,1223
416.67,3480,1180,1222
416.64,3480,1180,1223
416.74,3472,1180,1222
416.67,3480,1180,1223Starting read test, please wait.
read speed and latency
speed,max,min,avg
431.53,2368,1168,1180
431.53,1248,1172,1180
431.56,1252,1168,1180
431.53,1256,1168,1180
431.56,1252,1168,1181Done
The FAT12 card has excellent write speed and latency properties since it truly has 512 byte flash write blocks.
Modern cards have huge flash write blocks and just emulate 512 byte blocks. Emulation requires moving data and programming many extra flash blocks. The Arduino just can't take advantage of modern cards that expect at least 16 KiB writes.
Here are results for a modern high end 32 GB SanDisk card. Write speed and latency suffers. Great read speed with big clusters.
Free RAM: 598
Type is FAT32
Card size: 31.91 GB (GB = 1E9 bytes)Manufacturer ID: 0X3
OEM ID: SD
Product: SE32G
Version: 8.0
Serial number: 0XF6D24F1
Manufacturing date: 5/2014File size 5 MB
speed,max,min,avg
282.90,20132,1532,1804
290.51,11328,1652,1756
289.62,11352,1652,1762
291.41,11336,1636,1751
291.20,11336,1652,1752
290.70,11340,1652,1755
290.14,11268,1648,1758
291.41,11324,1656,1751
291.14,11348,1652,1752
291.12,11300,1652,1753Starting read test, please wait.
speed,max,min,avg
499.72,2004,992,1019
499.57,2004,992,1019
499.67,2004,992,1019
499.52,2004,992,1020
Done
