Hello,
I started thi sproject where I have a green house and an arduino mkr1000, and I started to work on the IOT clound offered by arduino.
I have few sensors: two dht11 (one for inside and one for the outside).
Based on temperature and humidity I want to a small panel to open so the air can come inside from this window.
I have a nema 17 stepper motor for open and close this sliding panel and two end switched (1 for th eleft and 1 for the right) that are telling to the stepmotor when to stop.
I connect everyning but I have a small problem with the stepper motor. It si working with the sample code that that we can find in the sample folder ("stepper_onerevolution") but with my code th stepper motor is not working, it is doing a weird noise. CAn you please look at my code and check if there is something wrong please.
#include "thingProperties.h"
#include <DHT.h>
#include <DHT_U.h>
#include <Stepper.h>
// DHT sensor library - Version: Latest
#define DHTPIN0 2 //dht int
#define DHTPIN1 4 // dht ext
#define WaterSolenoid1 3
int HumidityExt;
const int stepsPerRevolution = 200; // change this to fit the number of steps per revolution
// for your motor
// initialize the stepper library on pins 8 through 11:
Stepper myStepper(stepsPerRevolution, 8, 9, 10, 11);
#define DHTTYPE DHT11
DHT dht0(DHTPIN0, DHTTYPE);
DHT dht1(DHTPIN1, DHTTYPE);
// Initialize serial and wait for port to open:*
// This delay gives the chance to wait for a Serial Monitor without blocking if none is found*
//delay(1500); *
// Defined in thingProperties.h*
initProperties();*
// Connect to Arduino IoT Cloud*
ArduinoCloud.begin(ArduinoIoTPreferredConnection);*
dht0.begin();*
dht1.begin();*
pinMode(A1,INPUT);*
pinMode(WaterSolenoid1, OUTPUT);*
digitalWrite(WaterSolenoid1, LOW);*
// set the speed at 60 rpm:*
myStepper.setSpeed(60);*
// initialize the serial port:*
_ /*_
- The following function allows you to obtain more information*
- related to the state of network and IoT Cloud connection and errors*
- the higher number the more granular information you’ll get.*
- The default is 0 (only errors).*
- Maximum is 4*
_ */_ - setDebugMessageLevel(2);*
- ArduinoCloud.printDebugInfo();*
- Serial.begin(9600);*
- ArduinoCloud.update();*
- // Your code here *
TempInt = dht0.readTemperature();
HumidityInt = dht0.readHumidity();
TempExt = dht1.readTemperature();
HumidityExt = dht1.readHumidity();
LightInt = analogRead(A1);
digitalWrite(WaterSolenoid1, HIGH);
Serial.print("Temp Interna: ");*
Serial.print(TempInt);*
Serial.print(F(" Umidity interna:"));*
Serial.print(HumidityInt);*
Serial.print(F(" Luce"));*
Serial.print(LightInt);*
Serial.print(F(" Solenoide:"));*
Serial.print(WaterSolenoid1);*
Serial.print(F(" UmiditĂ esterna:"));*
Serial.print(HumidityExt);*
// step one revolution in one direction:*
Serial.println("clockwise");*
myStepper.step(stepsPerRevolution);*
delay(500);*
// step one revolution in the other direction:*
Serial.println("counterclockwise");*
myStepper.step(-stepsPerRevolution);*
delay(500);*
void onTempIntChange() {
void onWaterSolenoid1Change() {
- // Do something*
