Good evening,
so, well, I'll just present my Arduino project.
I connected the Arduino to a 4x20 SerLCD2.5, read data out of the Serial Stream and saved that into a variable. The var then got displayed on the LCD.
After I had a lot of fun displaying stuff on my LCD, I thought "Why shouldn't everyone be able to do that?". So I wrote a PHP Script and a small Program in C#. Now people can access my website, write there some greeting down, then my C# program on my local computer reads the greeting over a php script out of the MySQL-Database and sends it via the Serial Port to the Arduino, which displays the greeting. After a Test-Run, I saw that some Idiots thought it would be funny writing down racist/nazi stuff, so I had to implement a wordfilter, a logging-System and a ban system. To prevent flooding there can be only 1 greeting all 5 minutes.
If anyone wants the link to the website, PM me or something, I don't like when it gets spammed. :>
Schematic (german, but I think it isn't too complex):
I'll just paste the very messy coded C#-Program and the Arduino Code. But I think the PHP-Script is too shitty to share
C#
using System;
using System.IO;
using System.IO.Ports;
using System.Net;
using System.Text;
public class greetme
static SerialPort _serialPort;
public static void Main()
StringComparer stringComparer = StringComparer.OrdinalIgnoreCase;
while (true)
_serialPort = new SerialPort();
_serialPort.PortName = "COM5";
_serialPort.BaudRate = 9600;
_serialPort.Parity = Parity.None;
_serialPort.DataBits = 8;
_serialPort.StopBits = StopBits.One;
_serialPort.Handshake = Handshake.None;
//Webrequest
StringBuilder sb = new StringBuilder();
byte[] buf = new byte[128];
HttpWebRequest request = (HttpWebRequest)
WebRequest.Create("URL_HERE");
HttpWebResponse response = (HttpWebResponse)
request.GetResponse();
Stream resStream = response.GetResponseStream();
string tempString = null;
int count = 0;
do
// fill the buffer with data
count = resStream.Read(buf, 0, buf.Length);
// make sure we read some data
if (count != 0)
// translate from bytes to ASCII text
tempString = Encoding.ASCII.GetString(buf, 0, count);
// continue building the string
sb.Append(tempString);
while (count > 0); // any more data to read?
resStream.Close();
response.Close();
//Senden
if(stringComparer.Equals("", sb.ToString()) == false)
_serialPort.Open();
_serialPort.Write(sb.ToString());
_serialPort.Close();
//Console.WriteLine(sb.ToString());
System.Threading.Thread.Sleep(10000);
Most of the code is copy-pasted from somewhere, I couldn't even program C# when I started with the project.
Okay, I'll just make a short explanation:
The PHP-Script index.php first removes all registered IPs which are older than 5 minutes (function time()) and not banned, then it gets the post data for the greeting-Parameter. If it's not "" (nothing), it checks for bad words (MySQL-Query, stristr-PHP-Function) After that, it checks that the IP of the user hasen't been registered lately. If everything is ok, it sends 2 MySQL-Querys: One to add the IP (and the time of adding) of the greeter, and one to add the greeting.
Last but not least in the greeting-routine, it adds a new entry in the log-table with IP, time and message.
At the end of the Script, it will just present a HTML-Form for the greeting.
In a second script, it first checks if the password in the get-parameter is the right one, then it gives out the first greeting (MySQL-Query just needs a "LIMIT 1" at the end) with echo and deletes it. That's it.
A little overview of the databasetables:
Log
greeting
greeters
banned_words
ip
id
id
word
msg
msg
ip
warn
time(Timestamp)
timestamp(PHP-Timestamp this time
banned
The warn-Field at "banned_words" is 1 or 2. The bannedword-check in the script adds the warn-values of each bad word in the greeting. If the result is 2 or higher, the ip will get banned. So if someone writes something about his ass, he won't be banned instantly.
I hope you can understand it, I know, I could have done it better =D
Since you are german: www.schattenbaum.net has good PHP and MySQL-Tutorials in german. Helped me alot!
