Hello everybody,
I have a problem with my code.
I have two serie communication.
One for the COM5
One for the SIM800 on GPIO 7, 8
I send a command on the SIM800 to read the SMS.
At this point all is ok.
Now i want to “GREP” the text message because I have too much information on the Serial COM5.
Maybe my code is not fine i don’t know.
If somebody can help me.
Here is my code
// If you have a pin code please put that code before setup :
// String SIM_PIN_CODE = String( "XXXX" );
// And put that code on setup :
// sim800l.print("AT+CPIN=");
// sim800l.println( SIM_PIN_CODE );
// Import of library.
#include <SoftwareSerial.h>
SoftwareSerial sim800l(7, 8); // RX, TX
String text; // to storage the text of the sms
char inchar;
void setup() { // Start of setup.
Serial.begin(9600); // Start of modem.
sim800l.begin(9600); // Initialisation of serie communication.
sim800l.print("AT+CMGF=1\r");
text=sim800l.print("AT+CMGL=ALL\r");
Serial.println(text);//do nothing
if (sim800l.available())
Serial.write(sim800l.read());
if (Serial.available()) {
while(Serial.available()){
sim800l.write(Serial.read());
sim800l.println();
String ledOn = "Result command of AT+CMGR=1"; HERE IS MY PROBLEM
Serial.println(ledOn);
// substring(index) looks for the substring from the index position to the end:
if (ledOn.substring(100,102) == "on") {
Serial.println("You did it");
// you can also look for a substring in the middle of a string:
if (ledOn.substring(100, 104) == "Test") {
Here is an example of the COM5 print :
Thnaks for help
