Hi.
I have a number of questions here on a project I'm working on. I'm using an NRF24L01 to transmit to a scoreboard. My project is created from a small circuit board, an Arduino Mini Pro, 3 diodes, 3 capacitors, a keypad an NRF and 2xAA batteries.
Questions:
- I've created a ground plane on both sides of the circuit board (connected to the battery negative). On the underside of the NRF unit, the antenna has 5 pins (4 in a square shape, then 1 in the middle). All 5 pins seem to all be connected together to the GND pin on the small board (when checked with my multimeter). Does this mean I should connect them to my ground plane?
- Also, all 5 of these pins seem to be connected together (again when tested with my meter). This is the 4 pins in square formation as well as the centre pin. Is that normal?
- Is it best to connect at least the 4 pins to my ground plane to reduce interference and/or transmission distance?
- To minimize interference, someone suggested wrapping plastic wrap around the NRF unit, then some tin foil. Would this really help minimise interference. I'm worried if moisture ever got into this unit, it might "short out"
- Is it worth "covering" the NRF with a layer of plastic from a hot melt glue gun, then cover the whole unit in foil?
- In the code, I've included the line: myRadio.setPALevel(RF24_PA_MAX);
This can be set to MAX, HIGH or MIN. Can someone please explain to me what effect this does. I personally found that on MIN, the voltage to operate it could drop to 1.925V, whereas on MAX it had to be 2.030. Does this also affect transmission distance (or use extra battery current)?
