Grounding Active Subwoofer?
Hi guys.
This is not something to do with Arduino products but is within the field of audio.
I have the following Subwoofer in my home powered with a modded PC ATX power supply but isn't enough to deliver the right current to the amp and the thin yellow 12v wires get too warm at times.
I've been doing some searching for an alternate means of powering my subwoofer in my home and have found a regulated power supply that might just cover it. I just really need some advice.
The subwoofer in mention: https://www.amazon.co.uk/Edge-Pre-Loaded-subwoofer-Enclosed-Black-Orange/dp/B0031HUI4W
The regulated power supply I found: https://www.amazon.com/dp/B00YRIRRS4/ref=sspa_dk_detail_6?psc=1&pd_rd_i=B00YRIRRS4 But I need something capable of running 40A 750W peak, 250W RMS.
Amp wiring kit I would use: https://www.amazon.com/Foot-Gauge-Featuring-Oversized-Cables/dp/B00ED3BHBG/ref=sr_1_2_sspa?s=electronics&ie=UTF8&qid=1543950556&sr=1-2-spons&keywords=amp+wiring+kit&psc=1
Only question is where and how would I ground the amp...? I know in order to power the regulated power supply I'd need to strip a kettle lead and use it's pos, neg and earth wires to connect to the supply.
I'm surprised the wires are overheating, but yeah... I think most of the power (wattage) for a computer power supply is from the 5V output.
That would probably work fine... Normal program material has about a 10:1 peak-to-average ratio so at 750W peak you're only consuming about 75W on average. There is some inefficiency in the amplifier so the power supply need to supply a little extra current but in the real world you should be fine. But you do need the current on the peaks so you'll need something "bigger" if you want to be sure you're getting full-power.
[u]Here[/u] is a higher-power power supply. Or, [u]Digi-Key[/u] (or Mouser) sell all kinds of power supplies. The "nominal" voltage of a fully-charged car battery is 14.4V so you could go 14.4V or even 15V and you might get more power (which you probably don't need).
The negative power supply output (or common) goes to the ground (or negative supply connection) on the amplifier (powered speaker). There is usually no need to earth-ground the power supply output, and earth-grounding might create a ground loop which could introduce noise.
The DC & audio ground is just a common connection point. For example, the ground in a car isn't earth-grounded, it's just a connection to the chassis/body. If your audio system is earth-grounded there may be a true-ground through the audio cables, but that's not important (unless you get a ground loop, etc.). Sometimes the audio ground isn't connected to the DC ground either.
The power supply's ground terminal (normally connected to the power supply case) must be earth grounded for safety reasons.
Or you can go to the hardware store and buy the plug & wire, or you can buy a heavy-duty extension cord and cut-off one end, etc.
With these screw-terminal AC connections I like to cover the connections with hot-glue so nobody can accidently touch the lethal voltage. (I'm pretty sure the whole power supply is supposed to be mounted inside another cabinet so nobody can touch it.)
Firstly that wiring kit uses CCA wire, so its crap, avoid.
Only get genuine copper wires, not CCA. This means in practice if you use eBay you'll have to buy a short sample of wire from the vendor first to check its copper and not aluminium, they buy the full length if its genuine.
The size of wire is governed by the amount of loss that is acceptable and the max current handling of the wire itself.
Assuming you will want to pull 40A with only 0.5V drop over a cable run of N meters, that means wire of about 6/N milliohms per meter. So 3m run would want 2mohm/m, for total resistance of 0.002x3x2 = 0.012 ohms.
At that current the total power loss is 20W into the cable, so the power handling needs to be 10/N watts/meter.
There are many tables of wire resistance and max current ratings out there.
But with copper wire you can assume a resistivity of 1.7 x 10^-8 ohm-meters as a good guide. resistance = length(meters) x resistivity / area(sq meters)
Its easier to calculate as R = length x 0.017 / area (sq mm)
or resistance per meter = 0.017 / area (in sq mm)
For instance a 2mohm/m wire would be about 8mm^2 of copper
DVDdoug:
With these screw-terminal AC connections I like to cover the connections with hot-glue so nobody can accidently touch the lethal voltage. (I’m pretty sure the whole power supply is supposed to be mounted inside another cabinet so nobody can touch it.)
Yes, the supply is only for use inside a box. Hot glue is not the answer. (It will simply melt and
make a mess anyway since you have lots of waste heat being generated).
Okay so as far as amp grounding, I simply wire the ground wire from an amp kit to the ground power supply terminal?
