"Grouping" integer values from an array
Hi guys, newladybye here :) In my project i receive a byte array of 12 elements 3 of these elements are integer values ( from 0 to 9) that represent a code for another purpose. For example data[0]= 5 ,data[1]= 6, data[2]= 3;
i'd like to "group" them up to create a longer integer that represents this code ( in this case code=563) I'm a newbie in programming so... how can i do that?
You could add '0' to each one, and add a character 0 to the end of the array - thus turning it into a string.
So majenko you mean something like : code1 =data[0] + '0'; code2 =data[1] + '0'; code3 =data[2] + '0'; code4='0'; String newstring = code1+code2+code3+code4 ;
@HazardMinds i looked for atoi() but it seems to do the opposite of my purpose . It converts a string to integer, i need to take integers and create a longer integer
Hell no. Stay away from String like the plague!
It's as simple as:
data[0] += '0';
data[1] += '0';
data[2] += '0';
data[3] = 0;
Serial.println((char *)data);
Add '0' to each entry of the array. Remember, a character is just a human representation of a number, so just add a pre-set number to each entry so it represents the right character (in this case '0' - the ASCII character 0 not the integer 0). Slap 0 on the end (C string terminating NULL character) and treat it like a C string (cast it to char *).
majenko: Hell no. Stay away from String like the plague!
It's as simple as:
data[0] += '0';
data[1] += '0';
data[2] += '0';
data[3] = 0;
Ok, thank you, now it's more clear...... but what about making comparisons with this ?
As i represented in my first post , i can make comparisons doing : if ( data == 563 ) ............... or if (data == "563") ................... ?
int newint = data[0] * 100 + data[1] * 10 + data[2];
You end up with a C string, so you can use all the C string functions, such as
if (strcmp(data, "563") == 0) {
  // yes, they match
And you can convert to an integer with atoi:
int val = atoi(data);
Or if you just want an integer you can do as David suggests and calculate it from the values by multiplying each digit by 10n.
Thank you all guys!!!! i will try both solutions and then use the one that has best perfomances :)
Thank you majenko, David and of course all others that have partecipated this discussion. I think i should study more of C language ..... :)
