Grove - Finger-clip Heart Rate Sensor with shell Coding
Hi i am currently working on a project whereby i am using a Grove - Finger-clip Heart Rate Sensor with shell with an Arduino UNO. I am using the following; GND, 5V, A4 and A5 connections.
I am having problems obtaining the sensors i2c address. All i2c scanners are not finding any devices.
I am using the following coding to use the sensor;
#include <Wire.h>
  Serial.println("Heart Rate Sensor");
  Wire.begin();
  Wire.requestFrom(0xA0 >> 1, 1);    // request 1 bytes from slave device
  while (Wire.available())          // slave may send less than requested
    unsigned char c = Wire.read();   // receive heart rate value (a byte)
    Serial.println(c, DEC);         // print heart rate value
Someone please help me URGENTLY and let me know where i am going wrong and how i can get the sensor working. I am not an expert with arduinos so i may be a silly mistake that i am making.
Thanks! :slight_smile:
What is the urgency, exactly?
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
What do you see in the serial monitor, you have the monitor speed set at 9600bd?
aarg:
Well I am currently working on a project and i need to get coding working asap to meet deadline. :frowning:
Do you have any solutions to this problem?
i think it may be the i2c address... but i am unable to obtain an i2c witht the i2c scanner..........
If the scanner can't see it, it isn't wired correctly.
Do you have 4.7k pullup resistors on a4 and A5? (maybe the Grove already has those but you didn't post a link)
Are SDA (A4) and SCL (A5) wired correctly?
Pete
el_supremo:
Pete
Yeah i am using a universal grove 4 pin cable and connecting SDA-A4 and SCL-A5.
Also sorry i am new to Arduino so i do not fully understand what you mean by 4.7k pullup resistors on a4 and a5??? can explain further please.
Thanks
This is the schematics for the grove heart rate sensor
https://www.pdf.investintech.com/preview/723c8f32-6a96-11e7-922a-002590d31986/index.html
Thanks.. Tom.. :slight_smile:
TomGeorge:
These are images of the actual basic component connection
And these are the schematic drawings of the uno
(Although this is not an original Arduino UNO being used, i also have an original Arduino UNO and have slotted the wires in the correct slots SDA (A4) and SCL (A5). Still get the same results)
@TomGeorge
@el_supremo
Thanks!!
Here is a clearer link of the schematics if needed.
https://drive.google.com/drive/folders/0B6uNNXJ2z4Cxc3VwZHNaUkM3eGs
Is my wire.requestfrom() wrong??
The diagram in the latest link you posted makes it possible to read the circuit labels. The circuit does not appear to have pullups on SDA and SCL. If the pullup resistors aren't hidden in the Open-Smart board, you'll have to add a 4.7k resistor from A4 to +5V and from A5 to +5V.
Pete
Yes, but you need to get the I2C scanner to see the device before worrying about that.
Pete
el_supremo:
Pete
Oh right! secondly how do i add 4.7k resistors as pull up resistors A4,A5??
@el_supremo
Thanks!!
Adding a 4.7k pullup resistor? Or do i need to modify wire.h file???
wire.h file has nothing to do with it. You need to add two physical resistors as I described previously.
Pete
el_supremo:
Pete
Watch this youtube video:
The only thing is that this guy has not added any additional resistors. I have also used my arduino uno and plugged into female pins as the guy in the video has but still locating on I2C scanner.
@el_supremo
:frowning:
I saw another video of a guy using the sensor with a real UNO and he didn’t have pullups either. In that case I don’t know why the scanner doesn’t find the I2C address.
Pete
el_supremo:
I saw another video of a guy using the sensor with a real UNO and he didn't have pullups either. In that case I don't know why the scanner doesn't find the I2C address.
Pete
hmm maybe mine is faulty i will try purchasing another and see how that goes
Thanks!!
