Hi everyone,
I have an automated greenhouse system running and the last thing I wish to do is to implement a GPS system using the Grove GPS module. I had been doing everything using TI Launchpads but decided to break off and use arduino for this one. I am sure this is pretty trivial but I have been struggling and the previous posts regarding this haven't helped me too much.
I have a grove GPS module, Grove base shield, and Seeeduino Lotus v1.0 and I was trying to implement the SoftwareSerial example code from the Wiki in the Arduino IDE. I should also mention that I have done the necessary steps to allow the Seeeduino to work with the IDE and that worked just fine. My issue is that when I plug the GPS into the Digital 2 port of either the Seeeduino or Base shield+Seeeduino, my output is the expected serial output minus the GPS coordinates and other values (as seen in the picture below). The Grove Wiki seems vague to me so I was wondering if I need to purchase an additional Softserial Shield on top of the Seeeduino and base shield or is there a simpler way to do this? Sorry, I am sure this is trivial.
Thanks!
Justin
