Grove I2C 3-axis Accelerometer troubles
Hello,
I'm trying to use the Grove I2C 3-axis accelerometer with Arduino UNO (sketch and phtoto is in the attachment).
It works fine for several iterations (usually about 100-200)
Then it stops sending data. =(
I've tryed to use accelerometer with and without pull-up resistors, but result is exactly the same.'
Where is the root of the problem?
Thanks for advance.
accel.ino (1.77 KB)
Please use code tags for code. (The # button when composing a posting)
  while(Wire.available()) {
    if(count < 3) {
      while ( val[count] > 63 )  // reload the damn thing it is bad
        val[count] = Wire.read();
      count++;
That code will call Wire.read() when nothing is available to read. You are not guarding the calls to read() properly.
