Grove mp3 player shield
J’ai un probleme avec le code de ce composant (mp3 player shield) :
//    Function: control the seeedstudio Grove MP3 player
//      Hardware: Grove - Serial MP3 Player
#include <SoftwareSerial.h>
SoftwareSerial mp3(3, 4);//modify this with the connector you are using.
    mp3.begin(9600);
    delay(100);
    if (true ==SetPlayMode(0x01))
    Serial.println("Set The Play Mode to 0x01, Single Loop Mode.");
    Serial.println("Playmode Set Error");
    PauseOnOffCurrentMusic();
    SetPlayMode(0x01);
    SetMusicPlay(00,01);
    SetVolume(0x0E);
    while(1);
//Set the music index to play, the index is decided by the input sequence
//of the music;
//hbyte: the high byte of the index;
//lbyte: the low byte of the index;
boolean SetMusicPlay(uint8_t hbyte,uint8_t lbyte)
    mp3.write(0x7E);
    mp3.write(0x04);
    mp3.write(0xA0);
    mp3.write(hbyte);
    mp3.write(lbyte);
    mp3.write(0x7E);
    delay(10);
    while(mp3.available())
        if (0xA0==mp3.read())
        return true;
        return false;
// Pause on/off  the current music
boolean PauseOnOffCurrentMusic(void)
    mp3.write(0x7E);
    mp3.write(0x02);
    mp3.write(0xA3);
    mp3.write(0x7E);
    delay(10);
        if (0xA3==mp3.read())
        return true;
        return false;
//Set the volume, the range is 0x00 to 0x1F
boolean SetVolume(uint8_t volume)
    mp3.write(0x7E);
    mp3.write(0x03);
    mp3.write(0xA7);
    mp3.write(volume);
    mp3.write(0x7E);
    delay(10);
        if (0xA7==mp3.read())
        return true;
        return false;
boolean SetPlayMode(uint8_t playmode)
    if (((playmode==0x00)|(playmode==0x01)|(playmode==0x02)|(playmode==0x03))==false)
        Serial.println("PlayMode Parameter Error! ");
        return false;
    mp3.write(0x7E);
    mp3.write(0x03);
    mp3.write(0xA9);
    mp3.write(playmode);
    mp3.write(0x7E);
    delay(10);
        if (0xA9==mp3.read())
        return true;
        return false;
Non seulement je ne comprends pas que font les commandes boolean et mp3.write et lorsque je mets des musiques sur ma carte SD il n’en joue qu’une seule en boucle
Pouvez vous m’aidez svp?
