Grove mp3 player with ATMEGA328P
Hi!
i have some problem on playing audio file of mp3 player with Atmega328P:
Grove mp3 player is working fine with Arduino board.
However when i take out the atmega328p(use as standalone),connecting it with grove mp3 player it is not able to function.
TX(Grove mp3 player)-->pin7(Arduino pin) RX(Grove mp3 player)-->pin8(Arduino pin)
Crystal is already added to atmega328p.
please help, thanks!
Please post a schematic of your not working system. It sounds like your stand alone is not working. Will it do a simple blink LED sketch?
Yes!
the atmega328 is also connected to LCD and LED in my project Both of them is working
only the mp3 player not working
there are 4 wires of mp3 player vcc gnd TX RX
TX--->DIGITAL PIN 7 RX--->DIGITAL PIN 8
Did you connect the grounds?
@Isaac96
YES! ground and vcc is already connected.
Grumpy_Mike: Please post a schematic of your not working system.
@Grumpy_Mike
i don't have the schematic diagram currently
basically my connection is base on "Crystal ball" example and then
i add a LED to arduino pin 6 , distance sensor to arduino pin A0(14) grove MP3 player to arduino pin 9 and pin 10
You claim to have something that works using a standard arduino and then when you transfer the chip to your home made system it dosn't work. That only leaves your home made system that can be at fault.
As you can make stuff without a schematic you must be much much better than me so I can't help you. Sorry.
