can you share some example ?
My existing project looks as it is
and Code
#include <ModbusMaster.h>
//RS485 //DI TX0 //DE pin3 //RE pin2//R0 RX0
//ENCODER
//RS485
#define MAX485_DE 3
#define MAX485_RE_NEG 2
// instantiate ModbusMaster object
ModbusMaster node;
void preTransmission() {digitalWrite(MAX485_RE_NEG, 1);digitalWrite(MAX485_DE, 1);}
void postTransmission() {digitalWrite(MAX485_RE_NEG, 0);digitalWrite(MAX485_DE, 0);}
uint8_t result,j;
uint16_t data[6];
//RS485
volatile unsigned int temp; //this variable will increase or decrease depending on the rotation of encoder
int counter = 0; // initial point of rotary encoder
int candleLenght = 1040; // Lenght -> signal for cutting candle
int RELAY1 = 8; // relay for something else
int x; // var for operate RELAY1 on/off
boolean runMotorOneTime = false; //for running motor once
unsigned long currentMillis;
//LED
const int ledPin40 = 40; //cut signal millis
const int ledPin41 = 41; //watchdog green
int ledState40 = HIGH; // ledState used to set the LED
int ledState41 = LOW; // ledState used to set the LED
long previousMillisWDOG = 0;
long watchDogInterval = 250;
long previousMillisCutLED = 250;
long CutLedInterval = 250;
int S1; //button status for candle L
int S2; //button status for candle L
int S3; //button status for candle L
//candle lenght buttons
pinMode(31, INPUT); //S1
pinMode(32, INPUT); //S2
pinMode(33, INPUT); //S3
//Encoder
pinMode(21, INPUT_PULLUP); // internal pullup input pin 21
pinMode(20, INPUT_PULLUP); // internal pullup input pin 20
//Setting up interrupt A rising pulse from encodenren activated ai0(). AttachInterrupt 2 is DigitalPin nr 20.
attachInterrupt(2, ai0, RISING); //0 & 1 taken by RS485
//B rising pulse from encodenren activated ai1(). AttachInterrupt 3 is DigitalPin nr 21.
attachInterrupt(3, ai1, RISING); //0 & 1 taken by RS485
//Encoder
//RS 485
pinMode(MAX485_RE_NEG, OUTPUT);
pinMode(MAX485_DE, OUTPUT);
// Init in receive mode
//RS 485
Serial.begin (9600);
Serial1.begin (38400);
Serial.println("Serail Ready");
pinMode(RELAY1, OUTPUT);
digitalWrite(RELAY1, HIGH); //RELAY 1 is OFF
// Modbus slave ID 1
node.begin(1, Serial1);
// Callbacks allow us to configure the RS485 transceiver correctly
node.preTransmission(preTransmission);
node.postTransmission(postTransmission);
writeMotorParams();
readMotorParams();
// delay(500);
S1 = digitalRead(31);
S2 = digitalRead(32);
S3 = digitalRead(33);
currentMillis = millis();
runMotor();
//value of counter from encoder
// if( counter != temp ){
// //candleLenghtButton();
// temp = counter;
// //Serial.println (temp); //<-- if uncomment runMotor() not run at all, serial is buisy
******* ANGLE ENCODER COLLECT DATA AND PASS FOR CUTTING SIGNAL *************
void ai0() {
if (digitalRead(21) == LOW) {
counter++;
//Serial.println(counter);
//if (counter % candleLenght == 0 ) { //activate cutCandle for RUN motor
if (counter % candyL(S1,S2,S3) == 0 ) { //activate cutCandle for RUN motor
x = !x;
cutCandle(x);//cut candle RUN motor + var y for relay to do something else
//counter--; //we do not want count anticlockwise
void ai1() {
if (digitalRead(20) == LOW) {
counter++;
// Serial.println(counter);
x = !x;
*************************** CUT CANDLE **************************************
int cutCandle(unsigned int x) {
if (x == 1) {
digitalWrite(RELAY1, HIGH); //relay for something else OFF
// Serial.println(currentTime);
//Serial.println("activate cutting solenoid OFF"); //<--lagging if uncomment
counter = 0;
if (x == 0) {
digitalWrite(RELAY1, LOW); //relay for something else ON
//Serial.println(currentTime);
//Serial.println("activate cutting solenoid ON"); //<--lagging if uncomment
counter = 0;
*************************** MOTOR DATA **************************************
void writeMotorParams() { //Setup the motor driver after hard reset
//308 = 0x0134 fan of driver 1off
//901 = 0x0385
//902 = 0x0386
//903 = 0x0387 RPM
result = node.writeSingleRegister(0x0004, 8); delay(50);
result = node.writeSingleRegister(0x0134, 1); delay(50);
result = node.writeSingleRegister(0x0385, 0); delay(50);
result = node.writeSingleRegister(0x0386, 1000); delay(50);
result = node.writeSingleRegister(0x0387, 300); delay(50);
void readMotorParams() {
result = node.readHoldingRegisters(0x0386, 1); // Control mode selection
if (result == node.ku8MBSuccess){
Serial.println("***SOME PARAMETER : ***" );
for (j = 0; j < 1; j++) {
data[j] = node.getResponseBuffer(j);
Serial.print("Control Mode selection P00.04 => "); Serial.print(j); Serial.println(data[j]);
void runMotor(){ //MOTOR ON
if (runMotorOneTime == false){
ledCutSignal();
ledWatchDog();
result = node.writeSingleRegister(0x0384, 1);
node.clearResponseBuffer();//if not clear can lagging
Serial1.flush();//if not clear can lagging
runMotorOneTime = true;//stop motor exit from method
Serial.println("MOTOR => CUT ON");
//Serial.println(millis());
//delay(25);
void ledWatchDog(){
if(currentMillis - previousMillisWDOG > watchDogInterval) {
// save the last time you blinked the LED
previousMillisWDOG = currentMillis;
// if the LED is off turn it on and vice-versa:
if (ledState41 == LOW)
ledState41 = HIGH;
ledState41 = LOW;
// set the LED with the ledState of the variable:
digitalWrite(ledPin41, ledState41);
void ledCutSignal(){
if(currentMillis - previousMillisCutLED > CutLedInterval) {
previousMillisCutLED = currentMillis;
if (ledState40 == LOW)
ledState40 = HIGH;
ledState40 = LOW;
digitalWrite(ledPin40, ledState40);
*************************** CANDLE LENGHT ***********************************
int candyL(int s1, int s2, int s3 ){
long l;
if(s1 == 0 && s2 == 0 && s3 == 0) // 0-0-0
l = 1040;
else if(s1 == 1 && s2 == 0 && s3 == 0) // 1-0-0
l = 1140;
else if(s1 == 1 && s2 == 0 && s3 == 1) // 1-0-1
l = 1240;
else if(s1 == 1 && s2 == 1 && s3 == 0) // 1-1-0
l = 1340;
else if(s1 == 1 && s2 == 1 && s3 == 1) // 1-1-1
l = 1440;
else if(s1 == 0 && s2 == 1 && s3 == 1) // 0-1-1
l = 1540;
else if(s1 == 0 && s2 == 0 && s3 == 1) // 0-0-1
l = 1640;
else if (s1 == 0 && s2 == 1 && s3 == 0) // 0-1-0
l = 2000;
l = 1000;
return l;
Simple replacement Max RS485 to Grove RS485 dosent works, for some reason...
